This block is broken or missing. You may be missing content or you might need to enable the original module.
Teledyne e2v Announces 8K Image Sensor for Logistics Applications
New 8K image sensor delivers wide FOV for high-throughput logistics vision systems
Wed, 07/26/2023 - 11:59
(Teledyne: Grenoble, France) -- Teledyne e2v, a Teledyne Technologies company and global innovator of imaging solutions, announces Snappy Wide, a new 8K-wide aspect ratio CMOS image sensor designed specifically for logistics applications where larger conveyor belts are becoming increasingly common. A single Snappy Wide sensor can cover this large field of view successfully, replacing multiple sensors for a more efficient and cost-effective solution.
Snappy Wide has a small 2.5 µm global shutter pixel, designed with Teledyne e2v’s latest generation light pipe technology, which provides 67 dB dynamic range in 10-bit and 12-bit ADC mode. The sensors have low readout noise, which is paramount for barcode reading, with a good MTF in any kind of environment, and low dark current to ensure pristine image quality, even in very low-light conditions. With a maximum resolution of 8K (8,192) x 4k (4,320) pixels (i.e., 17/9 aspect ratio), Snappy Wide provides innovative sensor solutions for the logistics market and other industrial applications, such as smart factories.
