A Security Technique to Fool Would-Be Cyber Attackers
Safeguarding secret information while enabling faster computation
Adam Zewe
Thu, 03/17/2022 - 12:02
Multiple programs running on the same computer may not be able to directly access each other’s hidden information. But because they share the same memory hardware, their secrets could be stolen by a malicious program through a “memory timing side-channel attack.”
This malicious program notices delays when it tries to access a computer’s memory, because the hardware is shared among all programs using the machine. It can then interpret those delays to obtain another program’s secrets, like a password or cryptographic key.
One way to prevent these types of attacks is to allow only one program to use the memory controller at a time. But this dramatically slows down computation. Instead, a team of MIT researchers has devised a new approach that allows memory sharing to continue while providing strong security against this type of side-channel attack. Their method is able to speed up programs by 12 percent when compared to state-of-the-art security schemes.
In addition to providing better security while enabling faster computation, the technique could be applied to a range of different side-channel attacks that target shared computing resources, the researchers say.
You Might Like...
