Marposs Announces Simple, Turnkey System for Leak Testing of Blood Lines
Compact system provides semiautomatic testing and error proofing, helping reduce operator motion and overall cycle time
Tue, 06/08/2021 - 12:00
(Marposs: Auburn Hills, MI) -- Marposs, a world leader in measurement, inspection, and test technologies, has announced the availability of its Tecna T2 leak tester and AV10 test fixture solution developed specifically for verifying the integrity of medical blood lines. Featuring the reliable Tecna T2 pressure decay leak tester with an integrated pneumatic test fixture, this compact system provides semiautomatic testing and error proofing, helping to reduce operator motion and overall cycle time.
The T2/AV10 automatically starts the test when the operator connects the blood line to the system and automatically releases it at the end of the test if the test is positive (passed). In the case of a fail, the fixture will not release until the operator acknowledges the failure. Featuring an easy-to-read 3.5-in. color LCD touchscreen, the “Passed” or “Failed” results are displayed for individual tests as well as totaling the results. The AV10 can be configured with customer-specified connector types and sizes.
The T2/AV10 offers leak test with full scale up to 6 bar and 1 Pa (0.01 mbar) resolution on leak reading. The test pressure can be regulated with a manual precision pressure regulator with pressure indicated on the display.
