Resolve Surface Details at the Nanometer Level With 3D Laser Confocal Scanning Microscopy
Laser confocal scanning microscopy is ideal for inspecting complicated surfaces
Sponsored Content
Sponsored Content
Guangnan Meng
Tue, 08/14/2018 - 12:01
Modern 3D laser confocal scanning microscopes can resolve fine surface topography detail as minute as a few nanometers, quickly and easily. It’s the solution that advanced manufacturing industries turn to for efficient quality assurance surface inspections.
The changing needs of surface and interface engineering
Many of the modern conveniences that we have today are due to industrial engineering innovation and improvements. Much of this evolution and innovation depends on the precise engineering of surfaces and interfaces. For example, car engine performance and fuel economy depend on the surface finish of the piston and engine block. The nanostructured surfaces of anodes and cathodes of batteries ensure their reliable charging performance and long use life. The surface finish of electrical steel affects the energy conversion efficiency of the motors of electric vehicles, as well as the audio quality of amplifiers.
Surface and interface engineering is a critical aspect of various emerging technologies, and a lot of research and development efforts are focused on finding the best surface designs for next-generation industrial revolutions.
Ensuring the quality of the surface finish of parts in a manufacturing environment is challenging. Surface inspection has become a topic of discussion in many quality assurance departments across industrial disciplines. Quality assurance experts have to achieve detail at the nanometer level while weaving through related practical constraints, such as maintaining the original surface condition, accelerating the inspection speed to meet the manufacturing throughput, and meeting the size and weight requirements of the final parts. They also need to think ahead to the future because the inspection process may need to be adapted if the manufacturing process changes. Conventional mechanical stylus profilometers cannot meet all these needs.
Advantages of laser confocal scanning microscopy
Because of their noncontact approach, optical profilometers are becoming the common choice for surface-finish inspection. Among the optical surface profiling tools used, laser confocal scanning microscopy is an ideal choice, especially when the surface topology is rough and complicated.
Explore the why and how of measuring surface roughness here.
Precision imaging down to the nanometer level, reliably and easily
High-quality lenses are a critical consideration for a laser confocal scanning microscope to obtain sharp images and reliably acquire surface detail at the single-nanometer level. Metrology best practices include choosing lenses specifically designed for surface metrology applications, and their 3D-measurement performance.
Laser-confocal-scanning-microscope-lenses
Figure 1: Olympus’ OLS5000 laser confocal scanning microscope is equipped with a line of dedicated LEXT objectives that are specially designed for surface metrology applications. The optical performance of these objectives is tuned for the microscope’s 405 nm wavelength laser, helping ensure observations with minimal aberration across the field of view. In addition to high-performance objectives, low magnification (10x) and long working distance (LWD) objectives are also available to meet different application needs.
Figure 2: Measurement on the LEXT OLS5000 microscope is quick and easy. Users can simply place the sample on the microscope stage and start the measurement at ambient room conditions.
Laser-confocal-scanning-microscope-scan
Figure 3: With the LEXT OLS5000 microscope, users can avoid cleaving the part to get precise cross-sectional measurements. The image shows a high-resolution 3D height map (A) of a nickel micro-bump array, and a cross-sectional view (B) of the same nickel micro-bump array captured by the LEXT OLS5000 laser confocal scanning microscope.
Olympus’ LEXT OLS5000 laser confocal scanning microscope has a small, compact footprint, enabling it to conveniently fit on most desktop workspaces. It is also easy to customize and modify the mechanical mounting scheme to adapt to new inspection requirements. Compared to SEM and AFM systems, the OLS5000 microscope requires minimal maintenance, making it a cost-effective inspection solution.
Laser-confocal-scanning-microscope-setup
Figure 4: An example of a system setup for the LEXT OLS5000 laser confocal scanning microscope. It includes the OLS5000 microscope body, a controller, a desktop computer, and monitor.
For additional information about the LEXT OLS5000 laser confocal scanning microscope, please visit the Olympus website.
Editor’s note: Quality Digest will be presenting an episode of Quality Digest Live from the Olympus booth at IMTS on Thurs., Sept. 13, 2018, at 11 a.m. Pacific / 2 p.m. Eastern. During the broadcast, Olympus will be demonstrating its LEXT OLS5000 laser confocal scanning microscope. During the show the winner of a set of Olympus DPC I Series binoculars will also be announced. To enter for your chance to win, simply fill out the form below; you need not be present to claim the binoculars. Be sure to stop by Olympus’ booth (No. 135621) during IMTS, Sept. 10–15, 2018, in Chicago.
You Might Like...
Don’t Shake Before You Listen
