Marposs Announces New Compact Bankamp Machine Monitoring System
Stand-alone system for collision monitoring and crash damage mitigation in machine tools
Marposs
Wed, 04/04/2018 - 12:00
(Marposs: Auburn Hills, MI) -- Marposs Corp. has announced the availability of its new Brankamp CMS-02 stand-alone system for collision monitoring and crash damage mitigation in machine tools.
The system employs a ceramic strain sensor to detect irregularities in the production process by measuring elastic deformation in the range of 0.1 microns, and both slow and dynamically increasing forces which have damage potential. It then reacts extremely fast—in the range of 1 millisecond—by sending a stop signal to E-STOP helping to alleviate or even eliminate machine crashes that can result in high repair costs and long down times.
As compared to previous Brankamp (CMS-1) offerings, the CMS-2 is a compact, single-channel unit. It has 16 bits resolution, 25kHz sampling rate, three operation modes, and three limits per mode (warning, soft-, and hard-stop outputs limits), stop-event data recording, and signal values log file. Visualization of the data, analysis, and statistics, as well as the HMI, is realized by connecting an Ethernet cable to a Windows-based industrial PC unit or the newest IPC4 dedicated monitor.
