Compact Eight-Channel Type K Thermocouple Amplifier for Industrial Applications
Converts low-output voltage signals to linearized 0 to 5 VDC output voltages
The Sensor Connection
Mon, 10/20/2014 - 12:25
(The Sensor Connection: Troy, MI) -- The Sensor Connection, a division of Harold G. Schaevitz Industries, has expanded its line of measurement and control instrumentation with the addition of the model TCA-MS-K-8-A4. This amplifier module converts the low-output voltage signal from eight-channel, type K thermocouple probes to eight independent linearized 0 to 5 VDC output voltages. This output is ideal for interfacing to instrumentation equipment, including data loggers, temperature indicators, chart recorders, and controllers. A unique feature of this product is the addition of an onboard single-axis ± 4 G capacitive accelerometer for monitoring vibration or shock to the module.
