Mettler-Toledo Launches Smartcal Reference Substance
Fast new method for testing moisture analyzer performance
Mettler-Toledo
Tue, 03/20/2012 - 13:17
(Mettler-Toledo: Greifensee, Switzerland) -- Mettler-Toledo, a leader in the research and development of products and services in the precision instrument industry, has launched the SmartCal reference substance, designed to verify and document moisture analyzer performance.
SmartCal is a new quality control check based on a certified and traceable reference substance, which verifies instrument performance with a simple 10-minute moisture measurement.
A user-friendly, 10-minute test
The SmartCal test is easy to perform and requires only 10 minutes. Each single-use sachet contains 8.5 g of the defined moisture-content reference substance. The user simply places the contents of the sachet in the moisture analyzer and presses start. A straightforward pass/fail notification confirms if the result is within the specified SmartCal control limits, and the instrument is ready for use. SmartCal is a simpler alternative to the traditional, tedious method for testing moisture analyzers, which involves using a weight for balance calibration and performing temperature calibration with a thermometer.
