Product News: Long Range Gauge Sensor
GS-1000 uses the proven linear glass scale technology.
Ono Sokki
Thu, 03/04/2010 - 09:33
(Ono Sokki Technology: Addison, IL) -- Ono Sokki Technology Inc. reintroduces the GS-1000 linear gauge sensor. This gauge was designed to measure dimensions, thickness, curvature, eccentricity, displacement, height, depth, flatness, variation, run-out, roundness, distortion, deflection, and also used for load and pressure inspection applications.
This gauge sensor uses the proven linear glass scale technology. The main advantage of this principle is that you can maintain high consistent accuracy and super sensitivity throughout the entire range. The GS-1000 performs highly accurate measurements to 0.0005 in., throughout the full 4-inch measuring range along with a fast response speed of 39.4 in./second.
The carbon graphite spindle permits heavy lateral loading or side impact force. This is important because, typically the longer the measuring probe, the more it is susceptible to being damaged from side impact.
