Study Finds Failure Points in Firefighter Protective Equipment
Fire experiments help improve match between standard requirements and real-life conditions
NIST
Mon, 12/19/2011 - 16:50
(NIST: Gaithersburg, MD) -- In fire experiments conducted in uniformly furnished but vacant Chicago-area townhouses, National Institute of Standards and Technology (NIST) researchers uncovered temperature and heat-flow conditions that can seriously damage facepiece lenses on standard firefighter breathing equipment, a potential contributing factor for first-responder fatalities and injuries.
The findings are detailed in a report from a research study sponsored by the U.S. Fire Administration and Department of Homeland Security. The work is an important step toward improving what may be the most vulnerable component of a firefighter’s protective gear in high-heat conditions: the facepiece lenses of the so-called self-contained breathing apparatus, or SCBA.
Failure of the lens can expose a firefighter to toxic gases and can result in burns to the respiratory tract as well as asphyxiation. In several SCBA-related deaths, degraded masks were found affixed to the faces of victims while their equipment continued to supply air.
Why Remote Work Isn’t Working
Run It Past the Murder Board
