Understanding the Central Limit Theorem
Tumbling dice and birthdays
Minitab LLC
Minitab Inc.
Wed, 08/26/2009 - 05:00
Story update 8/27/2009: An error was spotted and corrected by author in paragraph starting with "The population mean for a six-sided die..."
Mark Twain famously quipped that there were three ways to avoid telling the truth: lies, damned lies, and statistics. The joke works because statistics frequently seem like a black box—it can be difficult to understand how statistical theorems make it possible to draw conclusions from data that, on their face, defy easy analysis.
But because data analysis plays a critical role in everything from jet engine reliability to determining the shows we see on television, it’s important to acquire at least a basic understanding of statistics. One of the most important concepts to understand is the central limit theorem.
In this article, we will explain the central limit theorem and show how to demonstrate it using common examples, including the roll of a die and the birthdays of Major League Baseball players.
Defining the central limit theorem
A typical textbook definition of the central limit theorem goes something like this:
Submitted by dws on Wed, 08/26/2009 - 10:27
Population standard deviation for numbers on a die
Since the population of numbers represented on faces of a die is 1 through 6, the divisor in the standard deviation equation should be n = 6 instead of n-1 = 5. For some reason, MINTAB does not show an equation for Population standard deviation. I can find only the equation for sample standard deviation. The correct value for population standard deviation in this case is 1.707825, as given by STDEVP in EXCEL.
Submitted by MEP on Thu, 08/27/2009 - 09:01
In reply to Population standard deviation for numbers on a die by dws
Population standard deviation correction
That is correct - I overlooked the n-1 denominator and will make the corrrection asap. Therefore "if the theorem holds true, the mean of the thirty averages should be about 3.5 with standard deviation 1.70783/sqrt(30) = 0.3118." Thank you for catching this.
