CMMS Success Metrics
How to build KPIs that prove results
Javad Esmaeili / Unsplash
Alexandra Vazquez
Limble
Wed, 06/17/2026 - 12:02
A lot of computerized maintenance management system (CMMS) rollouts fail quietly. It’s a common scenario: The software is installed, technicians are logging hours, and the digital work orders are flowing. On the surface, the implementation was a “success.” But when the VP of operations asks for a quarterly performance review, no one can explain the actual effect on the bottom line. The system runs, but the value is invisible.
This gap matters now more than ever. As industrial leaders demand data-backed proof for every dollar spent, maintenance managers have to move beyond just tracking “system adoption.” You need to tie your daily wrench-turning to cost savings, increased uptime, and extended asset life. If you can’t measure it, you can’t defend your budget or justify your head count.
Let’s talk about how to move past basic activity counts and build a reporting engine that proves your program’s worth to leadership.
Why Remote Work Isn’t Working
