Analysis Using Few Data, Part 2
Comparing the W-ratio test with a homogeneity chart
SPC Press
Wed, 10/24/2012 - 11:40
While an XmR chart is commonly used as a process behavior chart, it may also be used as a test of homogeneity for a finite number of values. This column explains the difference in these two uses of the XmR chart and compares the homogeneity chart with the W-ratio test, which I presented in my June column, Analysis Using Few Data, Part 1. In addition, this column contains an expanded table of critical values for the W-ratio test.
Why Remote Work Isn’t Working
