Timing Is Power: When to Lead and When to Hold Back
Stepping up at the right time can give you a competitive edge
OpenAI
Adam Galinsky
Maurice Schweitzer
Thu, 07/10/2025 - 12:02
Nano Tools for Leaders—a collaboration between Wharton Executive Education and Wharton’s Center for Leadership and Change Management—are fast, effective tools that you can learn and start using in less than 15 minutes, with the potential to significantly affect your success and the engagement and productivity of the people you lead.
Goal: Learn when leading the charge gives you a competitive edge—and when it’s better to wait.
