Featured Product
Metrology Features
Innovalia Metrology
Innovalia Metrology raises the bar for measuring, calculating, analyzing, and deciding
Ryan E. Day
FARO laser tracker helps Cincinnati Inc. keep pace with modern manufacturing
NIST
First detailed measurement-based study of how antenna beamwidth, orientation interact with environment
Mike Richman
Several views on developing the workforce
Interoperability is key to avoiding the manual steps and hand-offs that Industry 4.0 hopes to eliminate
More Features
Metrology News
New S1 systems offer high volume production testing of compression and extension springs
S-T optical equipment owners encouraged to register their equipment with Dorsey Metrology
They’re spring-loaded AC LVDTs ideal for roundness measurements, automotive testing and materials testing
Works with Marposs LVDT/HVT manual gauges
Metallography and hardness-testing techniques for steel, iron-based metals, and heat/surface-treated materials
Offering convenient and cost-effective friction materials testing for automotive industry
High-performance, 3D metrology value accessible to all industries
They are the ultimate solution in force measurement versatility
Designed to hold delicate round parts without distortion for vision inspection
More News
L.S. Starrett Co.
Metrology
Starrett Digital Gauges Put Force Measurement in Palm of Your Hand or a Stand
Published: Thursday, October 11, 2018 - 11:00
(Starrett: Athol, MA) -- The L.S. Starrett Co., a global manufacturer of precision measuring tools and gauges, metrology systems, and more, introduces its DFC and DFG Series of handheld Digital Force Gages.
Depending on the series, advanced automatic testing can be attained with the DFC Force Gage controlling a Starrett FMM Digital Force Tester, or basic testing can be performed using the DFG gage.
The Starrett DFC and DFG Digital Force Gages are part of the new Starrett L1 line of entry-level digital force measurement solutions. Optimized for production and quality control testing, the versatile, innovative architecture of the Starrett L1 system is designed for fast, easy-to-use, reliable, and repeatable operation. Click here to view a video and request a brochure.
Starrett DFC and DFG Digital Force Gages feature an easy-to-view high-resolution OLED color backlit display and auto-off function. A primary and secondary window shows test results, and out-of-tolerance results display in red. A simple multifunction keypad has softkeys that are programmable to the user’s most repetitive functions.
Adjustable sampling rates help capture peak loads, and filters can be applied to peak and display values. The Starrett L1 Digital Force Gages’ batteries provides more than 30 hours of continuous operation and have a USB port for transmitting data to a computer. The gages have a cast aluminum housing with a comfortable grip design for handheld testing, and a metric, threaded-top post enables screw-on attachments and clevis adapters that fit hundreds of Starrett test fixtures.
“Whether for simple, basic, economical testing via handheld gaging, or more advanced testing when mounted on our L1 stands, our innovative digital gages provide the ultimate solution in force measurement versatility,” says Emerson Leme, head of the Metrology Division at Starrett.
DFC Digital Force Gages
The DFC Series is a revolutionary concept for force measurement via a handheld force gage. The DFC may be used as an advanced digital force gage and controller with Starrett FMM Force Testers, or as an advanced digital force gage with Starrett MTL and MTH Manual Force Testers. The DFC Gage can serve as a universal interface where the user tests and can configure load limits, distance limits, break limits, crosshead travel direction, crosshead speed, and more. The DFC features a precise measurement accuracy of 0.1-percent full scale with internal data sampling at 25KHz. Display resolution is 10,000:1. The DFC features Bluetooth®, USB, and RS-232 communications plus digital I/O.
The DFG Series is a basic force gage that measures force at an accuracy of better than 0.2-percent full scale. It is ideal for basic handheld tensile and compression testing. Test set up and operation is fast, efficient, and easy. The DFG display shows the test direction and dynamic load during testing. Results are displayed at the completion of testing, including “Pass-Fail” when tolerance is applied. The gage will display statistics when results are saved to the gage’s internal memory, and it can store up to 50 test results in local memory.
Both the DFC and DFG Digital Force Gages are supplied with a complete accessory kit and carrying case that includes hook, notch, chisel and flat attachments, a chisel and point adapter, a 6-in. extension rod, and a NIST-traceable certificate of calibration.
When more sophisticated and complex testing is required, Starrett also offers a range of force solutions via its L2, S2, L2 Plus, and L3 Systems. Starrett force measuring equipment is manufactured in the United States, and is available to order now in several configurations including handheld force gages and digital and manual force-testing stands.
L.S. Starrett Co.’s picture
L.S. Starrett Co.
The L.S. Starrett Co., founded in 1880, manufactures more than 5,000 variations of precision tools, gauges, measuring instruments, and saw blades for industrial, professional, and consumer markets worldwide. Starrett, a company that has set the standard for fine precision tools in industry for more than 123 years, has rightfully earned the title “World’s Greatest Toolmakers.”
