Olympus Adds Features to Stream Micro-Imaging Software
Stream 1.9 allows image acquisition, processing, measurement, and storage
Olympus
Wed, 11/13/2013 - 16:17
(Olympus: Center Valley, PA) -- As an advanced micro-imaging software system designed to turn Olympus industrial microscopes into high-performance analysis tools, OLYMPUS Stream allows users to seamlessly acquire, process, and measure images, then create valuable data and reports. With the release of Stream 1.9, Olympus introduces users to a host of new software features designed to further enhance workflow and allow simple, flexible system operation.
Of significant importance to the new Stream system are two new materials solution features, Automatic Measurement and Coating Thickness, that allow imaging and processing to be easily adjusted to better serve the analysis of samples.
Automatic Measurement allows the creation of complex measurements using scanners by automatic detection of material edges and pattern recognition. This materials solution automatically measures distances, circle diameters, and angles between two lines. Automatic Measurement also supports the multiple stage location and sample alignment with OLYMPUS Stream Motion.
