New Gas Permeability Tester Released
Qualitest’s VAC-V1 is engineered with data curve-fitting in permeation technique
Qualitest USA LC
Qualitest USA LC
Tue, 11/16/2010 - 17:28
(Qualitest: Huntsville, AL) -- Qualitest, a provider of comprehensive solutions through material-testing instruments, systems, and accessories, has extended its range of products for measuring gas permeability rate. The new gas permeability tester VAC-V1 is ideally suited to measure the gas permeability rate, solubility coefficient, diffusion coefficient, and permeability coefficient at various temperatures for plastic, laminated, and breathable films, high-barrier material sheets, foils, and rubber, including tire seal performance.
The VAC-V1 is engineered with a patented data curve-fitting in permeation (DCFP) technique that provides accurate test results at any temperature. The permeability tester is fully automated and computer-controlled with a wide test range that could be extended by means of the software. The VAC-V1 operates not only with oxygen but also nitrogen, carbon dioxide, and hydrogen. The device can even be extended to test for poisonous and explosive gases.
Why Remote Work Isn’t Working
Run It Past the Murder Board
