Navitar Introduces Dual-View Imaging System
Allows you to capture an image and present it to two different sensors
Navitar Inc.
Tue, 03/27/2012 - 11:56
(Navitar: Rochester, New York) -- Navitar Inc., a developer and manufacturer of standard and custom-engineered optical solutions, has introduced a versatile, dual-view imaging system that allows customers to simultaneously view a single subject and capture an image at multiple fields of view.
For situations requiring multiple fields of view, Navitar’s dual view module offers, with just one setup, a single objective lens presented to two separate imaging channels. The channels can be fixed, zoom, or a combination of both. Two separate light sources and wavelengths can be used, allowing inspection of multiple types of materials. The use of different adapter tubes on each optical path provides a wider field of view than a traditional single-view system, without the hassles of changing workstations or lighting setups.
The dual-view system has a minimum potential optical magnification range of 0.09X to 6.13X, which corresponds to fields of view as large as a 120 mm diagonal on a 2/3 in. format sensor, down to a 0.65 mm diagonal on a 1/4 in. sensor. Maximum optical magnification using the dual-view system can range from 20X to 583X using a 50X objective.
You Might Like...
Implementing Manufacturing Training Programs in 2026
Otis Expands Little Engineers STEM Program Globally
CAISI Issues Request for Information About Securing AI Agent Systems
Baldrige Foundation Announces 2026 Leadership Awards
Michigan Metrology Announces Surface Roughness, Texture, and Tribology Course
