KoCoS Introduces the PROMET SE+ Microohmmeter
Microohm measurements with test currents up to 200 A
Thu, 07/09/2026 - 12:03
(KoCoS Messtechnik: Korbach, Germany) -- With the PROMET SE+, KoCoS Messtechnik AG introduces a new generation of its measurement system for mobile resistance testing.
The device is designed to support the early detection of critical contact issues and to integrate seamlessly into professional switchgear testing applications.
Evolution of an established measurement system
The PROMET SE+ builds on the capabilities of the previous PROMET SE. Microohm resistance measurements with test currents up to 200 A, simultaneous measurement at two test points, and integration into ACTAS test systems are retained. The established operating concept has also been maintained and is accessed via a graphical user interface.
At the same time, the new generation extends the system’s functionality to provide greater flexibility and efficiency in mobile testing applications.
Designed for mobile field use
An integrated lithium-ion battery enables operation independent of an external power supply. The device is operated via a 5-in. touchscreen, allowing direct control and evaluation of measurements onsite.
Why Remote Work Isn’t Working
Run It Past the Murder Board
