Digital Signal Conditioner Ideal for Strain Gauge Sensors
Connects to standard transducer while generating serial output
Electro Standards Laboratories
Thu, 01/27/2011 - 09:35
(Electro Standards Laboratories: Cranston, RI) -- The CellMite Model 4337 Digital Signal Conditioner with a 16-character auto identifying display is ideal for use with strain gauge extensometers used to test steel or with other industrial testing applications. The Model 4337 connects directly to a standard strain gauge transducer and simultaneously generates a serial output for direct connection to a PC and a scalable ±10V analog output for interface to data acquisition systems.
The CellMite Model 4337 is a complete digital signal conditioner for strain gauge sensors. It has storage for three calibrated sensors, each with integrated six-point calibration and independent, user-specified display setup parameters. When a TEDS-Tag-capable sensor is connected to the unit, that sensor is immediately identified by the CellMite, and its stored calibration data and display configuration are automatically loaded. If that sensor is removed and another TEDS-Tag sensor is connected, then its calibration data and display data are automatically loaded. Auto sensor identification and auto display identification require no user intervention and prevent field personnel from making errors due to incorrect sensor calibration or display setup.
