Digital Metrology Releases Multi-Band Surface Texture Analysis Software
Instantly separates surface texture into wavelength bands, displays data in highly intuitive, single-screen interface
Digital Metrology
Wed, 08/07/2019 - 12:00
(Digital Metrology Solutions: Columbus, IN) -- Digital Metrology Solutions, provider of measurement software, consulting and training, has released two new products for multi-band surface texture analysis. Bandify and Bandify3D instantly separate surface texture into wavelength bands and display the data in a highly intuitive, single-screen interface.
“To produce surface finishes that both look good and perform well, you need to understand the spatial wavelengths within the surface texture,” explained Dr. Mark Malburg, President of Digital Metrology Solutions. “A roughness number alone can’t tell you whether a paint coat will appear glossy, if a gasket will seal, or if a gear will make noise. Understanding the impact of various wavelength domains leads to a better understanding of these complex functions.”
Bandify is the first software tool designed exclusively to analyze surface texture simultaneously over several user-defined wavelength bands. The software reports wavelength-specific surface parameters, with user-defined tolerance bands to highlight out-of-spec conditions.
