Stylus or Optical: Which Should You Choose?
Both technologies have applications for measuring surface texture
Mike Zecchino
Digital Metrology Solutions
Mark Malburg
Tue, 01/06/2026 - 12:02
Choosing the correct instrument for surface texture measurement can be confusing, given the wide range of options. Stylus-based instruments are the most prevalent in manufacturing. Yet, measuring a surface with a sharp stylus can seem old-fashioned when so many noncontact optical techniques are now available.
In reality, both stylus and optical technologies have their place. Here’s a look at applications where each technique excels or has limitations.
Texture is more than roughness
Before we delve into surface texture measurement, it’s important to remember that surface texture is not a number: Texture consists of many “shapes,” which can be described as a spectrum of “wavelengths” ranging from shorter wavelength “roughness” to longer wavelength “waviness” and “form.”
