Laser Scanner Helps Auto Supplier Cut Inspection Time
An automotive supplier reduced the time needed to inspect foam parts by two thirds by switching from a CMM to a laser scanner.
C. Martin Schuster
Wed, 08/10/2005 - 22:00
Foam Design Inc. of Lexington, Kentucky, builds a wide range of foam parts, including inserts for headliners used to protect against injuries in the event of a collision. Inspecting these components with a CMM was a tedious and error-prone process because of the difficulty involved in making contact with the part while not pressing down the soft material. A customer gave Steve Scrivner, quality manager for Foam Design, the idea of improving the speed and accuracy of the inspection process with a laser scanner. “The laser scanner has reduced the amount of time needed to lay out a first article from about an hour to under 20 minutes,” Scrivner said. “Just as important, the accuracy of the measurements has been substantially improved because this noncontact measurement method eliminates the danger of depressing the part surface.”
You Might Like...
Why Quality Must Evolve for the Next Generation of Manufacturing
80% of Healthcare Firms Are Exploring AI for Quality Management
When Quality Decays
What’s a 150-Year-Old Meat Chopper Have to Do With America’s Favorite Sports Car?
How to Pitch Big Ideas to Senior Stakeholders
