Case Study: CMM Plus Laser Probe Equals Gains
The new addition helps an aerospace supplier provide more complete inspection.
Wed, 07/13/2005 - 22:00
By adding a laser probe to a coordinate measuring machine (CMM), Sonaca, a large Belgian aerospace-structures supplier, has greatly increased the completeness of its inspections, obtaining full documentation of every component’s geometry. When the company inspected sheet metal components in the past, 3-D shape was validated by using two complementary methods: Base shape was controlled by comparing them to Mylar patterns on a light table, and 3-D shape was controlled via manual methods. Using CMMs to inspect the complex sheet metal parts would have required a long programming process for each of the many different parts produced by the company. “We found the ideal solution to this problem by adapting a laser probe on a CMM,” says Anne-Laure Schurins, Sonaca’s quality control manager in Gosselies, Belgium. “In a few minutes, the laser probe generates millions of points that completely describe the geometry of the part. We import the point cloud into a software package that compares it to the actual part geometry and highlights any discrepancies. Finally, we save an electronic file that provides complete documentation of the part geometry.”
Run It Past the Murder Board
