How to Control Quality Risk When Motion-Control Parts Become Obsolete
The first step is to separate inconvenience from true process risk
icetray/Adobe
Jesse Walker
Wake Industrial
Tue, 04/21/2026 - 12:02
In a lot of plants, motion-control equipment stays in service far longer than anyone originally expected. Servo drives, spindle amplifiers, operator panels, encoder interfaces, and power supplies often keep running for years after the OEM has shifted its attention elsewhere.
That long service life is great for capital efficiency. But it creates a quality problem that many teams don’t treat as such until production is already disrupted.
When a critical motion component becomes obsolete, most people think first about downtime. That makes sense, because downtime is visible and expensive. But the bigger issue is often process drift. A line may still run after an emergency replacement, but it might no longer run the same way. Axis response can change, registration can slip, stopping distance can shift, and machine-to-machine consistency can suffer. What started as a maintenance event quickly becomes a quality event.
However, obsolescence doesn’t have to be chaotic. If quality, maintenance, and engineering teams treat legacy automation parts as controlled process risks rather than one-off purchasing headaches, they can reduce both scrap and unplanned downtime.
Here’s a practical way to do it.
3 Things You Should Never Say When Presenting
