AI Brings Order to Label Diversity
Vision AI Label Reader automates label capture and ensures process reliability
IDS
Sabine Terrasi
IDS Imaging Development Systems
Thu, 07/09/2026 - 12:02
Inbound receiving operations (aka goods-in) in the electronics industry are under increasing pressure.
Countless components from a wide range of manufacturers arrive with constantly changing label layouts, multilingual markings, and ever shorter throughput times. What once could be managed manually has now become a bottleneck. Damaged barcodes or reflective packaging further increase effort and make processes more error-prone.
The Vision AI Label Reader from collective mind (COMI) demonstrates how this complexity can be managed. The AI-based image processing system automates the capture and interpretation of item information in goods-in and logistics, regardless of layout, language, or code type. Designed for industrial use, the solution improves process reliability, enhances data quality, and streamlines workflows. A uEye CP industrial camera from IDS Imaging Development Systems provides the image data required for analysis.
