Complex Global Supply Chains Simplified
The value of electronic kanban systems and rapid deployment
Thomas R. Cutler
Wed, 03/23/2016 - 14:39
It’s no surprise that multinational companies have complex global supply chains. What’s less obvious is how to simplify supply-chain processes and arrive at a lean, consistent, reliable, and cost-effective solution. One global leader, ITT Corp., has taken on this challenge with the help of Ultriva, a supply-chain solution by Upland Software, which supplies cloud-based manufacturing and supply-chain collaboration and execution solutions.
Why Remote Work Isn’t Working
Run It Past the Murder Board
