When an issue arises, it’s important to take quick action. Whether that means launching a software patch, pulling a batch, or halting the use of a reagent, it’s critical to tackle the immediate problem.
But just as critical as “How do we fix this?” is “How do we make sure this doesn’t happen again?”
That’s where the root cause analysis (RCA) comes in. This guide walks you through conducting an effective root cause analysis that takes you from “problem fixed” to “process improved.”
What is a root cause analysis?
“Root cause analysis” is just a fancier way to say, “Find out why this issue really happened.”
Instead of just treating the symptoms, a root cause analysis aims to identify the ultimate reason a problem occurred so you can take steps to prevent the issue from arising again.
For example, maybe you discover a sample was stored at the wrong temperature. Did the storage machine malfunction? Did someone adjust the temperature to the wrong setting? Is the temperature gauge accurate?
You can discard the sample so it doesn’t affect future tests, but until you find the reason—or the root cause—of the issue, you won’t know what preventive actions need to be taken.
When do you need to conduct a root cause analysis?
For any event you officially define as an issue, you must perform a root cause analysis.
That doesn’t mean every root cause analysis must be a massive undertaking. The key is to match the scale of your investigation to the severity and risk of the problem.
If a technician makes a minor clerical error in a batch record, a quick investigation might show it was just a one-off mistake caused by typing a little too fast. You log it, identify the root cause as human error, confirm it’s an isolated incident, and move on.
But what if that same technician makes the same error every month? That’s a pattern worth investigating further. “Human error” is no longer a sufficient root cause, and your root cause analysis should dig deeper. Is the batch record template confusing? Is the technician’s training incomplete? Is their workload too high, leading to rushed work? The investigation becomes lengthier and more comprehensive because the risk of a recurring issue is higher.
How to conduct a root cause analysis, step by step
The length of your investigation may vary based on the severity of the problem, but all root cause analyses tend to follow the same steps.
Step 1: Assemble the right team
Your first move is to pull in the right people. For your investigative team structure, you have some options. It could be:
• A formal committee with representatives from different departments (e.g., quality management, manufacturing, regulatory)
• The quality management team exclusively
• One dedicated “investigator” whose job is to interview people and collect information
• An ad-hoc team assembled specifically for the issue at hand
Regardless of the structure, your team must include two key groups.
Subject matter experts (SMEs): These are the people who understand the process, equipment, or material involved, inside and out. If there’s an issue within the lab assay, you need the lab analyst. If a piece of manufacturing equipment fails, you need an engineer. It’s not the investigator’s job to automatically know the answers. They must find the answers, and for that, you need the SMEs.
The person(s) involved: You need a firsthand account of what happened, so talk directly to the person who was performing the task when the issue occurred, and/or the person who noticed and reported the issue.
Step 2: Write a crystal-clear issue description
Before you can uncover the “why,” you have to clearly articulate the “what.” This is the issue description that must be included in your root cause analysis documentation. The goal is to write the issue description so that a total stranger (like an auditor) can read it and understand the situation inside and out. A strong issue description captures the who, what, when, and where.
Who: Who discovered the issue? Who reported it? Who was performing the task? Use clear identifiers, whether that’s full names or first initial and last name.
What: What exactly happened? Give as much detail as you possibly can. Not just “a reagent failed,” but “Reagent Kit Lot #123 failed its quality control check, yielding out-of-spec results for Assay XYZ.” Avoid acronyms, abbreviations, or confusing jargon.
When: Get the exact date and time, down to the minute if possible, and time zone (e.g., Aug. 27, 2025, 2:37 p.m. PST).
Where: Where did it happen physically (e.g., Lab 3, Cleanroom B, Manufacturing Site A)? And where in the process? Was it during a specific client’s batch? Multiple batches? On a specific line? This helps define the scope and impact of the issue, ultimately informing your overall action plan.
Be careful: These questions are deceptively simple.
A broken gauge might have been reported on Aug. 3, but how long has it been that way? How do you know it wasn’t noticed earlier but not reported? Has it affected other samples? What checks are in place to confirm that your other temperature gauges are working correctly? Take your time and view the situation with a wide lens to make sure you capture the problem completely.
Step 3: Start asking ‘why’
This is the core of the investigation. The most common technique is the 5 Whys method, a problem-solving technique used to find the real root cause of an issue by repeatedly asking the question “Why?” (“5 Whys” is a bit of a misnomer; regardless of how many times it takes, you’ll keep asking “why” until you hit the core of the problem.)
Here’s an example for a product sample that yielded an out-of-specification test result.
1. Why was the test result out of specification? The test equipment detected a large, unexpected peak, indicating the sample was contaminated.
2. Why was the sample contaminated? The glassware used to prepare the sample contained residue from a cleaning solvent.
3. Why did the glassware contain residue? It wasn’t properly rinsed with deionized water after being washed with the solvent.
4. Why was the glassware not properly rinsed? The new lab technician who washed the glassware wasn’t aware that a final rinse with deionized water was required.
5. Why was the technician unaware of this requirement? The technician was trained using a one-page work instruction posted near the sink; however, this document is an outdated version of the official SOP and omits the final rinsing step.
At this point, you might think the outdated SOP is the root cause of the issue, but it’s actually still a symptom or contributing factor. Even if we replace the SOP with the updated version, how do we know there aren’t more outdated SOPs floating around the premises? A similar problem could easily arise again. There’s still another “why” we can ask.
6. Why was the outdated SOP still in the lab? The organization lacks a formal document control process and document management tool for retrieving and destroying outdated printed materials when a new version becomes effective.
It’s now easier to see the necessary preventive action: The organization needs a formalized document control process, and likely an eQMS or eDMS.
Step 4: Categorize, fix, and reassess
Categorizing your root causes can help you identify trends or weak spots in your processes. It’s common for life sciences organizations to use frameworks like the 6 Ms to explore potential causes related to:
• Man: The people involved in the process
• Machine: The equipment and tools used
• Method: The procedures and SOPs being followed
• Material: The raw materials and inputs required
• Measurement: Data from product specifications or process monitoring
• Mother Nature: The environment (e.g., temperature, storm-caused power outage)
Once you’ve gotten to the heart of the issue, it’s time for a corrective and preventive action (CAPA), which should be directly derived from your root cause analysis. If the root cause was an unclear SOP (method), your CAPA will be to revise that SOP and retrain the team.
And don’t forget, your quality system must include a process for checking that your changes were effective. That could mean monitoring the process for three months or performing an audit a year later to ensure the problem hasn’t returned.
The best tool for conducting root cause analysis
A thorough root cause analysis involves coordinating people, gathering evidence, documenting findings, and tracking actions. It can be a lot to manage, and doing it all with paper, email, and spreadsheets is a recipe for chaos and missed steps.
This is where an electronic quality management system (eQMS) becomes a game-changer.
Centralized collaboration and documentation: An eQMS makes it easy to rally the troops. Instead of sending documents around for review and signature, everything is stored in a single electronic record that all assigned team members can access, review, and sign off on.
Linked evidence for audits: A robust eQMS allows you to directly link your investigation to other critical records. You can link to the SOP that wasn’t followed, link to previous recurring issues, and link the newly revised SOP as evidence that you fixed the problem. This creates a clean, easy-to-follow audit trail.
Data-driven insights: An eQMS with custom fields and reporting dashboards enables you to easily track key metrics related to your issues. Which root cause category is most prevalent? Are you seeing recurring human errors that point to a training gap? This business intelligence helps you identify your biggest weaknesses and focus your improvement efforts.
Accountability and timeliness: An eQMS helps you stay on track with CAPA deadlines. Automated reminders and dashboards show you what tasks are coming due (or are already overdue), helping you actually complete your action plans on time.
Ultimately, an eQMS transforms your RCA process from a reactive, paper-shuffling exercise into a proactive, data-driven engine for continuous improvement.
Published Sept. 3, 2025, by Zen QMS.
Root Cause Analysis
This is a good article. I have three tongue-in-cheek additions:
1. For chemical process analysis, question the instrument, then the instrument operator, then the process equipment, then the process operator, then the area manager, then the plant manager. Always equipment before people. In the end, if the problem doesn't go away, fire the plant manager.
2. Another approach I call the Magnusson method. Call the team together and solicit solutions. Act on every good idea. If the problem goes away, retire to the bar to reach a consensus regarding which action solved the problem. If the solution merely hides the problem, guess how long it will take for the product/service customer to discover what happened and find a new supplier.
3. You haven't said anything about really large political problems, illegal immigration for example. Now suppose you were assigned to determine the root cause of this issue in the US. And suppose you are a lifelong politician having no subject matter expertise. And suppose further the assignment came with a wink and a nod. What would you do? Would eQMS help? Should you just ignore the assignment other than doing a border flyover? Perhaps issue several "word salads"? Perhaps run for higher office which would allow you to assign someone else to the problem? Or go back to process 1, fire the manager, hire a new one, discover the scrap pile of uninstalled steel wall plates is still in place, install it, and ask the operators to do their job.
