Shimadzu Scientific Instruments Launches AUTOGRAPH AGS-V Series
Compact tabletop machines deliver high-precision materials testing
Mon, 07/14/2025 - 12:02
(Shimadzu: Columbia, MD) -- Shimadzu Scientific Instruments (SSI) introduces the AUTOGRAPH AGS-V Series tabletop precision universal testing machines. Featuring a wide selection of load cell capacities, versatile control options, and compatible accessories, the AGS-V Series delivers dependable testing of diverse material types.
Available in seven different models, the AGS-V Series supports load capacities from 1 newton to 10 kilonewtons, making it ideal for delicate samples and high-force testing applications. It also accommodates a wide test speed range of 0.0005 to 1,500 mm/min, providing greater adaptability for various test conditions. An improved crosshead return speed of 1,650 mm/min helps reduce test cycle times and boost lab productivity.
Expandable frame options are available to handle materials that undergo deformation, such as rubber and plastics. Users can increase both the testing stroke and main unit height with +250 mm and +500 mm extensions, enabling reliable tests to failure on highly elastic or stretchable materials.
ISO 9001:2026 Is Here
