Featured Product
Health Care Features
Jon Speer
As a medical device manufacturer, you can expect to be inspected
Taran March @ Quality Digest
Life science and tech companies bump heads to interpret the new map
Huge amounts of biometric, DNA, and diagnostic data enable personalized medicine. They also enable unscrupulous and discriminatory marketing.
Zach Y. Brown
Price transparency tools with useful, easy-to-use information can benefit patients and reduce healthcare costs
Stephen McCarthy
For quality, the future is still much bigger than the past
More Features
Health Care News
Certification bodies can conduct food safety audits and issue certifications of foreign food facilities
Creates adaptive system for managing product development and post-market quality for devices with software elements
Transforming a dysfunctional industry
An invite from Alcon Laboratories
Intended to harmonize domestic and international requirements
The FDA wants medical device manufactures to succeed, new technologies in supply chain managment
Neuroscientists train a deep neural network to analyze speech and music
Pharma quality teams will have performance-oriented objectives as well as regulatory compliance goals
More News
Rob Matheson
Health Care
Faster Analysis of Medical Images
Algorithm makes the process of comparing 3D scans up to 1,000 times faster
Published: Monday, July 16, 2018 - 12:01
Medical image registration is a common technique that involves overlaying two images, such as magnetic resonance imaging (MRI) scans, to compare and analyze anatomical differences in great detail. If a patient has a brain tumor, for instance, doctors can overlap a brain scan from several months ago onto a more recent scan to analyze small changes in the tumor’s progress.
This process, however, can often take two hours or more, as traditional systems meticulously align each of potentially a million pixels in the combined scans. In a pair of upcoming conference papers, MIT researchers describe a machine-learning algorithm that can register brain scans and other 3D images more than 1,000 times faster using novel learning techniques.
The algorithm works by “learning” while registering thousands of pairs of images. In doing so, it acquires information about how to align images and estimates some optimal alignment parameters. After training, it uses those parameters to map all pixels of one image to another, all at once. This reduces registration time to a minute or two using a normal computer, or less than a second using a graphics processing unit with comparable accuracy to state-of-the-art systems.
“The tasks of aligning a brain MRI shouldn’t be that different when you’re aligning one pair of brain MRIs or another,” says co-author on both papers Guha Balakrishnan, a graduate student in MIT’s Computer Science and Artificial Intelligence Laboratory (CSAIL) and Department of Engineering and Computer Science (EECS). “There is information you should be able to carry over in how you do the alignment. If you’re able to learn something from a previous image registration, you can do a new task much faster and with the same accuracy.”
The papers were presented at the Conference on Computer Vision and Pattern Recognition (CVPR), held June 18–22, 2018, and will be presented at the Medical Image Computing and Computer Assisted Interventions Conference (MICCAI), held Sept. 16–20, 2018, in Granada, Spain. Co-authors are: Adrian Dalca, a postdoc at Massachusetts General Hospital and CSAIL; Amy Zhao, a graduate student in CSAIL; Mert R. Sabuncu, a former CSAIL postdoc and now a professor at Cornell University; and John Guttag, the Dugald C. Jackson Professor in Electrical Engineering at MIT.
Retaining information
MRI scans are basically hundreds of stacked 2D images that form massive 3D images, called “volumes,” containing a million or more 3D pixels, called “voxels.” Therefore, it’s very time-consuming to align all voxels in the first volume with those in the second. Moreover, scans can come from different machines and have different spatial orientations, meaning matching voxels is even more computationally complex.
“You have two different images of two different brains, put them on top of each other, and you start wiggling one until one fits the other,” says Dalca, senior author on the CVPR paper and lead author on the MICCAI paper. “Mathematically, this optimization procedure takes a long time.”
This process becomes particularly slow when analyzing scans from large populations. Neuroscientists analyzing variations in brain structures across hundreds of patients with a particular disease or condition, for instance, could potentially spend hundreds of hours on the task.
That’s because those algorithms have one major flaw: They never learn. After each registration, they dismiss all data pertaining to voxel location. “Essentially, they start from scratch given a new pair of images,” Balakrishnan says. “After 100 registrations, you should have learned something from the alignment. That’s what we leverage.”
The researchers’ algorithm, called “VoxelMorph,” is powered by a convolutional neural network (CNN), a machine-learning approach commonly used for image processing. These networks consist of many nodes that process images and other information across several layers of computation.
In the CVPR paper, the researchers trained their algorithm on 7,000 publicly available MRI brain scans and then tested it on 250 additional scans.
During training, brain scans were fed into the algorithm in pairs. Using a CNN and modified computation layer called a spatial transformer, the method captures similarities of voxels in one MRI scan with voxels in the other scan. In doing so, the algorithm learns information about groups of voxels—such as anatomical shapes common to both scans—which it uses to calculate optimized parameters that can be applied to any scan pair.
When fed two new scans, a simple mathematical “function” uses those optimized parameters to rapidly calculate the exact alignment of every voxel in both scans. In short, the algorithm’s CNN component gains all necessary information during training so that, during each new registration, the entire registration can be executed using one easily computable function evaluation.
The researchers found their algorithm could accurately register all of their 250 test brain scans—those registered after the training set—within two minutes using a traditional central processing unit, and in under one second using a graphics processing unit.
Importantly, the algorithm is “unsupervised,” meaning it doesn’t require additional information beyond image data. Some registration algorithms incorporate CNN models but require a “ground truth,” meaning another traditional algorithm is first run to compute accurate registrations. The researchers’ algorithm maintains its accuracy without those data.
The MICCAI paper develops a refined VoxelMorph algorithm that “says how sure we are about each registration,” Balakrishnan says. It also guarantees the registration “smoothness,” meaning it doesn’t produce folds, holes, or general distortions in the composite image. The paper presents a mathematical model that validates the algorithm’s accuracy using something called a Dice score, a standard metric to evaluate the accuracy of overlapped images. Across 17 brain regions, the refined VoxelMorph algorithm scored the same accuracy as a commonly used state-of-the-art registration algorithm, while providing run time and methodological improvements.
Beyond brain scans
The speedy algorithm has a wide range of potential applications in addition to analyzing brain scans, the researchers say. MIT colleagues, for instance, are currently running the algorithm on lung images.
The algorithm could also pave the way for image registration during operations. Various scans of different qualities and speeds are currently used before or during some surgeries. But those images are not registered until after the operation. When resecting a brain tumor, for instance, surgeons sometimes scan a patient’s brain before and after surgery to see if they’ve removed all the tumor. If any bit remains, they’re back in the operating room.
With the new algorithm, Dalca says, surgeons could potentially register scans in near real time, getting a much clearer picture on their progress. “Today, they can’t really overlap the images during surgery because it will take two hours, and the surgery is ongoing,” he says. “However, if it only takes a second, you can imagine that it could be feasible.”
“There is a ton of work using existing deep learning frameworks/loss functions with little creativity or imagination,” says Bruce Fischl, a professor in radiology at Harvard Medical School and a neuroscientist at Massachusetts General Hospital. “This work departs from that mass of research with a very clever formulation of nonlinear warping as a learning problem... [where] learning takes hours, but applying the network takes seconds. This is a case where a big enough quantitative change [of image registration]—from hours to seconds—becomes a qualitative one, opening up new possibilities such as running the algorithm during a scan session while a patient is still in the scanner, enabling clinical decision making about what types of data need to be acquired, and where in the brain it should be focused without forcing the patient to come back days or weeks later.”
Fischl adds that his lab, which develops open-source software tools for neuroimaging analysis, hopes to use the algorithm soon. “Our biggest drawback is the length of time it takes us to analyze a dataset, and by far the more computational intensive portion of that analysis is nonlinear warping, so these tools are of great interest to me,” he says.
First published June 18, 2018, on MIT News.
Rob Matheson’s picture
Rob Matheson
Rob Matheson is a writer, editor, and web producer at MIT News, as well as a contributing writer at MIT Technology Review of the Massachusetts Institute of Technology in Cambridge, Massachusetts.
