Putting Einstein to the Test With the World’s Most Accurate Clocks
With hopes to someday combine two experiments and put an optical clock in space
Lucian Alexe/Unsplash
Gabriel Popkin
NIST
Tue, 03/24/2026 - 12:02
You’ve probably heard that time is relative. It sounds like a banal cliche, akin to “time flies when you’re having fun.”
But it’s no mere cliche: Time is relative. Though it’s not noticeable in daily life, time passes slightly more slowly when you’re moving vs. when you’re standing still. It also moves slightly more slowly when you’re at sea level than when you’re on top of a mountain.
We know this thanks to a remarkable timekeeping technology invented at the National Institute of Standards and Technology (NIST): the atomic clock. During the past half-century, scientists have designed a series of increasingly ambitious experiments to show that atomic clocks tick faster when moving and slower in stronger gravity. Now, a generation of clocks more precise than any that have come before is allowing physicists to push such measurements to new extremes.
Why Remote Work Isn’t Working
Run It Past the Murder Board
