Put AI Exceptions on the Quality Dashboard
AI adoption deserves the same discipline companies already expect from production, finance, and service quality
Vitaly Gariev / Unsplash
Gleb Tsipursky
Disaster Avoidance Experts
Tue, 12/01/2026 - 12:03
Companies are getting better at measuring how often employees use AI. They count licenses, prompts, minutes saved, and the volume of work generated. The dashboard can look wonderful even as staff spend their afternoons correcting the work that came out of those tools.
Quality leaders have seen this problem before. A process that produces more units per hour might still be a bad process when defects, rework, and customer complaints climb. AI belongs in the same quality-management discipline as any other consequential business process. The first step is to put exceptions, not merely adoption, on the management dashboard.
Consider a customer-service team that uses a writing assistant to draft explanations of warranty coverage. The staff approves most drafts quickly. A few contain an outdated exception to coverage, or cite a policy clause that applies to a different product. If managers track only draft speed and use, the pilot looks successful. A quality dashboard asks harder questions: How often does the tool create an error with consequences, who catches it, and what happens next?
The business case for measuring that work is becoming clearer. In its Nov. 5, 2026, report on a survey of 275 service and support leaders, Gartner found that 21% said they had reduced human-agent head count because of AI. Another 7% reported rehiring workers after earlier reductions. Those figures describe different organizations and don’t establish that a specific quality failure caused the rehiring. They do show why leaders need to demonstrate stable performance before making staffing decisions based on projected savings.
The American Management Association’s Oct. 28, 2026, analysis of its management survey adds another warning: 36% of managers said they spent more time during the previous year reviewing AI outputs. A separate 41% said AI had raised their expectations about how much work employees should complete. The extra review effort can quietly offset gains from faster drafting.
Start with the consequential error
A manager needs a short, shared definition of an AI exception. It’s an output that requires correction because it violates a verified source, misses a material qualification, introduces an unsupported conclusion, or puts a protected decision in the wrong hands. An awkward sentence may be worth editing, but it shouldn’t carry the same severity as the wrong coverage rule or an incorrect customer payment amount.
Build three severity bands. A minor exception adds routine editing time without changing the decision. A material exception would mislead a customer, employee, or partner if released. A critical exception could cause a financial loss, expose private information, violate an established control, or trigger an irreversible action. The organization should define these bands against its actual work and obligations, rather than rely on a universal list.
Have reviewers record five fields for each material or critical exception:
• Task type
• Source used
• Error category
• Correction time
• The person responsible for release
Record whether the employee caught it before the output reached its audience. This creates a small, usable defect register rather than a vague complaint that the AI sometimes gets things wrong.
Sample real work, including the uncomfortable cases
Don’t evaluate the tool only with polished demonstration prompts. Pull a regular sample of actual completed tasks, including work that staff accepted without changes. Stratify the sample by task type, employee experience, and consequence level so a high volume of easy drafts doesn’t conceal a low volume of costly failures.
For each sample, compare the finished output with its authoritative source and any known business rule. Ask whether a reviewer could trace the central claim to the correct policy, record, or customer instruction. An answer with an impressive-looking citation still fails if the citation supports a different proposition.
Track the denominator. Ten serious exceptions in 1,000 drafts, and 10 in 100 drafts, represent very different operating conditions. Report the number reviewed alongside the material-exception rate. Also measure the average minutes spent correcting outputs. Otherwise, a manager could announce that accuracy improved simply because fewer drafts received careful inspection.
Make the dashboard drive a decision
A useful weekly dashboard can fit on one page. Just put approved task volume next to the percentage of sampled work with a material exception. Add average correction time, repeat-exception categories, and the number of critical exceptions that escaped review. Then, give every recurring problem a named corrective-action owner and a due date. Where a baseline exists, show the change against the pre-AI workflow rather than a target invented after the pilot.
The central metric should be net usable work, measured after checking and correction. A team that drafts 40% faster but doubles its rework time may have achieved little practical gain. A slower tool that gives reviewers a reliable source trail could be the better choice for sensitive tasks.
Set a threshold before scaling. For example, a team might agree that a customer-facing workflow can’t expand to more accounts while any critical exception remains unexplained. The exact threshold should depend on the stakes, the baseline defect rate, and how rapidly an error can be reversed. A threshold without an owner or a response rule is simply decoration on a chart.
When a repeat error appears, change the system
Suppose reviewers repeatedly discover that the assistant omits a warranty exclusion buried in a footnote. Telling employees to be more careful won’t solve the recurrence. Investigate whether the approved source material is outdated, whether retrieval misses the footnote, whether the prompt emphasizes the wrong part of the policy, or whether reviewers lack a simple check for exclusions. Fix the cause, then test the changed workflow against the same exception cases.
This is the quality-management logic of corrective action: Describe the defect, identify its mechanism, assign the fix, test the revision, and confirm that the problem stops recurring. The quality team should preserve representative failed examples so the next model or workflow update must pass them. That turns a frustrating incident into an operational test.
Human review must also have boundaries. For a routine internal summary, a sampled check might be enough. Before a system sends a binding policy explanation, changes a financial record, or releases sensitive information, a specific accountable person may need to approve the output. Review that person’s actual ability to inspect the source, not merely whether the software displays an approval button.
AI adoption deserves the same discipline companies already expect from production, finance, and service quality. Put exceptions, correction costs, escape rates, and responsible owners beside the speed metrics. When managers can see what goes wrong and whether the fix worked, they can expand the workflows that genuinely improve performance and stop the ones that merely make the dashboard look busy.
3 Things You Should Never Say When Presenting
About text formats
