Downtime Isn’t Just a Maintenance Problem
It’s a strategic insight
valeo5/Adobe
Radhika Kumar
Trimedx
Thu, 10/29/2026 - 12:02
When hospitals treat device downtime as isolated, one-off incidents, they miss a critical opportunity to improve system reliability, manage long-term costs, and safeguard patient care. Downtime patterns often reveal far more than a single equipment failure; they point to the underlying condition of the asset fleet.
By elevating downtime data from an operational metric to a strategic planning input, healthcare technology management (HTM) teams can help health systems move beyond reactive fixes and toward informed, long-term capital decisions. Artificial intelligence now makes this work faster and easier to run throughout an entire device inventory.
What downtime tells health systems
Anytime a medical device fails, the immediate priority is getting it up and running as soon as possible. One U.S. study found that clinicians and staff spend at least 10% of their working time around operational failures, including situations where needed equipment isn’t available. Once the device is back in service, health systems often close the event and never revisit it, losing a useful view of how that equipment performs over time. Repeated service calls, recurring performance issues, or increasing maintenance demands can indicate reliability concerns and long-term operational risk.
Leading health systems are taking a more proactive approach and using AI-powered tools that review device performance in the entire inventory to spot patterns or warning signals.
Downtime data can reveal which assets are becoming increasingly costly to maintain, which devices may be approaching end of life, and where reliability issues could eventually disrupt patient care.
Turning downtime data into predictive intelligence
To interpret the warning signs correctly, HTM teams need to understand the factors driving downtime instead of simply tracking it. Not every downtime event points to a device that needs replacement, and not every performance issue signals a looming failure.
Real-time device monitoring and predictive analytics reveal performance trends for thousands of devices. By continuously analyzing device performance and service data, AI can help health systems identify which assets are performing as expected, which might require targeted intervention, and which could be candidates for future replacement. According to an Aquant report, service teams see a 39% improvement in resolution time when using AI, compared to traditional methods.
For example
In a small rural emergency department, a radiology and fluoroscopy system appeared to be operating normally despite occasional tube spits. Tube spits cause image artifacts and can lead to future device failure and costly tube replacements. The inability to predict device failures leads to unplanned downtime and disruptions to patient care. Although the issue seemed minor, predictive monitoring identified the recurring pattern and flagged it for investigation. A clinical engineering technician ultimately found the root cause was a generator issue, not a failing tube, preventing an unnecessary replacement and avoiding three to five days of unplanned downtime.
Discovering a root cause early prevents one unnecessary replacement. Doing it consistently for an entire inventory builds a record of where continued investment is justified and where it’s not.
Downtime insights can guide smarter capital decisions
Tight budgets and growing demand raise the bar on every repair decision: not just whether a device can be fixed, but whether fixing it is the best use of resources. By combining downtime trends with performance data, organizations can distinguish between assets that can continue operating reliably and those that are getting more expensive and less dependable. This enables a more strategic approach to capital planning. Instead of replacing equipment on a fixed schedule, health systems can direct capital toward the assets where it matters most—the ones where failure would most interrupt care.
During the early stages of implementing a centralized clinical asset management strategy at a large Midwestern health system, Trimedx’s predictive technology platform, TMX, enabled technicians to address dozens of issues with CT and MRI machines before a failure occurred. This saved more than 400 hours of equipment downtime and avoided revenue loss from canceled procedures.
Teams also used utilization history, maintenance records, and life cycle stage data to develop a five-year replacement road map for critical equipment. This approach grounds decisions in true need rather than assumptions or outdated records.
Shift from reducing downtime to eliminating it
Ultimately, health systems should strive to eliminate unplanned downtime, not just reduce it. One recent hospital study found medical equipment was unavailable an average of 8.78% of the time—with some critical equipment categories having downtime of more than 40%. Our own data show that health systems with predictive technologies in place have achieved 99% equipment uptime, preventing more than 1,200 downtime events annually.
As predictive technology matures, organizations can move beyond reactive maintenance and begin anticipating failures before they occur. Downtime data are critical to that transformation.
By changing how they treat downtime events, organizations can make smarter maintenance decisions and prioritize capital investments more effectively. By combining predictive intelligence with long-term planning, HTM teams can help create a future where equipment failures are exceedingly rare and patient care is less vulnerable to disruption.
About text formats
