Create Sustainable Results With Structure and Clarity
Strategy and the right people in key roles can establish a culture of improvement
MING Labs / Unsplash
Leif Nyström
CANEA
Tue, 11/10/2026 - 12:02
For improvement work to be successful, an organization needs a clear structure with defined roles and responsibilities. If it invests in an improvement organization for the long term, it can ensure lasting results. Here, we explore what an organization aimed at effective improvement might look like and which roles are crucial for success.
3 dimensions that work together: Line, process, and project
Most organizations have three main dimensions: line, process, and project. For improvement work to be effective, these dimensions must interact in a structured way.
The line dimension gathers daily resources and competencies. Line managers are responsible for recruiting, developing, and leading employees, as well as ensuring the organization has the capacity to drive improvement work.
Processes are repeated activities based on learning and continuous improvement. Process owners integrate experiences from previous projects and adapt working methods to maximize efficiency.
Projects are time-limited initiatives where specific improvements are implemented. Project managers are responsible for achieving specific goals within a given time frame and applying lessons learned to future projects.
Organizations can optimize their improvement efforts and build a sustainable culture of improvement by clearly understanding and utilizing the characteristics of these dimensions.
Key roles for successful improvement efforts
To succeed, you need the right people in the right roles. Here’s how some of the most common roles should be involved.
CEO/site manager: Sets the overall strategy and emphasizes the importance of improvement work in the long term. The CEO ensures that improvement initiatives are kept alive by regularly following up and communicating progress.
Business area manager: Responsible for identifying which value streams have the greatest potential for improvement and selecting which initiatives to prioritize.
Line manager: Leads the day-to-day work and supports employees in their pursuit of continuous improvement. Since line managers often have direct contact with employees, this role is crucial in making improvement work part of everyday life.
Team leaders: Leaders ensure that the team continues improvement work and works toward set goals. Team leaders are often directly involved in operational work and act as a bridge between management and employees.
Business developers/coaches: Drive continuous improvement initiatives and support leaders and teams. They help overcome obstacles and inspire employees to reach new levels of efficiency.
Process owners: Responsible for ensuring that processes run smoothly and suggesting improvements where necessary. Process owners keep track of the output of the process and its continuous development to ensure improvement work isn’t confined to a single department.
Value stream managers: Responsible for optimizing value streams that span multiple processes. They ensure that improvements in one part of the value stream don’t create problems in another part, and that the entire flow is adapted for maximum value creation.
Organize your improvement team
Depending on the areas needing improvement, the organization can benefit from different types of teams.
Line teams focus on improvements in specific areas. These teams often work within the same department and specialize in improving their own processes.
Process teams involve cross-functional groups with representatives from several departments. These teams work on improvements that require input from different parts of the organization, making them particularly effective for complex projects.
Project teams are created when major improvements are required. Led by a project manager, these teams include the necessary skills to ensure project success.
Organizations can tailor their improvement efforts to suit both specific needs and overall strategic goals by combining these team types.
An effective improvement organization requires a well-thought-out structure and clear roles to deliver sustainable results. With a strategy that integrates line, process, and project, and the right people in key roles, an organization can create a culture of improvement that drives the business forward.
Published by CANEA.
About text formats
