Analyzing Experimental Data
Why some studies can’t be replicated
SPC Press
Mon, 03/07/2022 - 12:03
Last month we looked at analyzing observational data. Here we will consider experimental data and discover a weakness in the way they are obtained that can contribute to the problem of nonreproducible results.
Background
The discipline of statistics grew up in agricultural and biomedical research. There a major problem for researchers is the fact that their basic experimental units are fields, livestock, and people. Since these units all differ, any researcher has to find a way to keep these differences from masking the effects of any treatments being studied. And the classic solution for this problem is some form of randomization.
Submitted by Scott A. Hindle on Mon, 03/07/2022 - 21:53
Extraneous factors
Thanks for this article. Some years ago I successfully proposed an experimental approach at a supplier’s location. The work was prepared well, with expectations raised that the experimental approach would help. There was one problem – critical as it happened – in relation to an extraneous factor. A leakage in the test rig – not a factor under study – pretty much ruined the experiment. Being there in person meant the problem was identified right away so at least no time was wasted in a naïve attempt to make sense of the data.
