Temperature Compensation
If and when to apply the coefficient of thermal expansion calculation
Tracker Handbook by Art Kietlinski
Tue, 05/10/2011 - 05:30
During the past 30 years I’ve had the opportunity to measure quite a few manufactured parts, machine tools, fabrications, and large vessels. I’ve also reviewed hundreds of metrology surveys done by technicians. Unfortunately, on more than one occasion I’ve seen data that were scaled incorrectly or not scaled at all. The results of incorrect thermal scaling may cause inaccurate data, showing faulty parts even if the parts are not faulty. It is essential to understand the purpose and importance of thermal scaling.
Unless otherwise noted, a drawing or model is scaled at 1, or 68°F. In quality labs, temperatures are consistent even though that may not always be the case. Measuring different parts in varying temperatures may cause the material to expand and contract due to thermal change. This change can be calculated by using the coefficient of thermal expansion (CTE). Most measurement software packages include the capability to apply the CTE calculation to the measurement file based on a particular material type.
Why Remote Work Isn’t Working
Run It Past the Murder Board
Submitted by lwehner on Wed, 05/11/2011 - 20:19
Thermal requirements
I have to agree with your statement about temperature compensation. And temperature is just one of the elements which can be overlooked when measuring parts with tolerances that become tighter and tighter. One thing I always tell new engineers is that all dirt has dimensions.Clean and dry parts are a must. Thats when new engineers start to realize that holding a part in your hands can cause measurement variation. And not just parts but masters and gauges as well. I'm sure that there are many engineers with stories that they can tell. Thanks for the article.
