Direct Liquid Filtration for Particle Analysis
Best practices for fluid sampling in cleanliness analysis
Peter Büscher
Thu, 03/16/2023 - 12:02
This article will focus on a sampling method that is commonly used to analyze fluid: direct liquid filtration. Simply put, direct liquid filtration is a sampling technique used to determine the particles present in a liquid.
In direct liquid filtration, the liquid with suspended particles is filtered through a membrane filter so the particles collect on its surface. Then the filter membrane is imaged with a light microscope for particle analysis. Keep reading to learn more about this fluid sampling method, including best practices to follow when extracting a fluid sample for cleanliness analysis.
Small particles, great effects: The importance of clean fluids in machinery
Shipping, energy, offshore, and pharmaceuticals are some of the industries that have discovered the benefits of clean fluids.
Milling machine using oil
ISO 9001:2026 Is Here
