Featured Video
Innovation Features
Aiman Sakr
One factory’s current problem is another’s potential failure mode
Rob Matheson
Algorithm makes the process of comparing 3D scans up to 1,000 times faster
Richard Wilson
Make sure your mobile QMS has these four features
Manufacturing Extension Partnership MEP
TechHelp can help inventors turn ideas into 3D CAD drawings, prototypes, a finished product
UPS becomes manufacturer, distributed management, and moonshine.
More Features
Innovation News
Other exhibits will feature machine tools to demonstrate tool setting, probing, machine monitoring, and robotic gauging
The custom-built, 727 cu in. Hemi engine will be raffled to support Victory Junction children’s camp
At annual entrepreneurship competition, eight teams pitched business ideas, and three took home cash prizes
Neuroscientists train a deep neural network to analyze speech and music
Preparing your organization for the new innovative culture
IoT solution includes advanced lab testing and real-world crowd testing
New system patches security holes left open by web browsers’ private-browsing functions
125 strategies to achieve maximum confidence, clarity, certainty, and creativity
MIT awards more than $1 million to organizations creating greater economic opportunity for workers
More News
Jarred Heigel
Innovation
Additive Manufacturing Equals Excitement
Regardless of what you call it, this technology benefits industry
Published: Thursday, July 14, 2016 - 17:06
I research additive manufacturing, which some people call solid free-form fabrication, but most people know as 3D printing. Additive manufacturing covers a wide range of processes that we can use to build parts and whole structures by strategically adding material only where we need it.
Building parts by adding material a bit at a time allows us to build geometries and features that we never could using traditional processes such as cutting, forging, or casting. For instance, with 3D printing we can make complex, ultra-lightweight parts by building their internal structures using the least material possible. We can build these parts complete with winding internal passages for fluids to flow, and we can make them out of different materials depending on the properties we need them to have, such as rigidity, or flexibility or the ability to conduct electricity or heat.
Image 1: The author at work. (Photo credit: F. Webber/NIST)
At the NIST Engineering Laboratory, where I’m a proud member of the Production Systems Group, we study the 3D printing processes, such as powder bed fusion (PBF) and directed energy deposition (DED), used to build metal parts. PBF uses an energy beam (either laser or electron) to melt thin layers of powdered metal that are incrementally spread across a build surface (bed). When the part is completed, you have to excavate it from the powder bed like a dinosaur skeleton at an archaeological dig.
Image 2: The additive manufacturing technique known as powder bed fusion uses an energy beam to melt thin layers of powdered metal that are incrementally spread across a build surface. (Photo credit: F. Webber/NIST)
DED also uses an energy beam to melt the metal, but instead of melting powder that has already been spread across the bed, metal in the form of powder or wire is fed into the beam, where it melts and fuses with previously deposited material. Unlike PBF, we can use DED to repair existing worn parts. We can also efficiently create a new part by first producing much of a part with conventional processes, such as casting or machining, then using DED to add only the necessary remaining features, such as an ultra-lightweight bracket or a fluid passage.
Unfortunately, large temperature fluctuations occur when we add molten metal to an evolving part. These temperature fluctuations can affect the material’s properties and create residual stress, i.e., atomic-level strains and deformities, which can affect the strength of the part and the accuracy of the part’s dimensions. All these concerns must be carefully considered and the manufacturing process well controlled so the final part meets the design requirements. In the most extreme (but all too common) cases, the part can deform so much that it breaks during the build or causes other issues that ruin the part.
Image 3: An infrared video taken during the production of a part. The 200-w laser is scanning back and forth to create 4 mm-wide lines. Metal particles are being ejected from the melt pool, complicating the measurement. Click to play. (Video credit: B. Lane/NIST)
Why do temperature fluctuations lead to failures? Well, you probably know that most materials expand when they heat up and contract as they cool. The localized heating we’re talking about occurs at rates of up to 1,000,000° C per second as the molten metal is fused to the part.
As you might imagine, this would cause just about anything to get out of whack.
Many of the current challenges with metal additive manufacturing can be solved through a better understanding of the materials and the process—and that means measurements. This is where my group comes into the picture. We are currently using a wide range of techniques, including thermal imaging, to learn about the process and to develop new measurement techniques needed by users of additive manufacturing systems.
Most of the problems I described above also occur in the consumer-level 3D printers for making plastic parts. These systems are currently popping up in companies, libraries, schools, and homes (I actually use one in my lab). The availability and low cost of these printers are some of the main factors fueling the current “maker movement.”
What’s exciting to me is that additive manufacturing systems can lead people down a path of scientific discovery. To create more accurate parts, you have to study your build to understand where the problem arose, research what others have done to solve similar problems, hypothesize and test possible solutions, and finally implement your fix. Working to solve these kinds of problems exposes you to fields as diverse as mathematics, heat transfer, material science, mechatronics, and programming—and could perhaps ignite a lifelong interest.
Image 4: The author with two metal objects printed by NIST’s Production Systems Group: a chess piece with an internal staircase and an object designed at NIST to test the capabilities of these machines. (Photo credit: F. Webber/NIST)
Additive manufacturing, and manufacturing in general, is a great example of interdisciplinary research. No matter your interest, your innovations can potentially lead to processing advancements that enable the production of better prosthetics and biological implants, aircraft components, or even the hardware necessary to explore Mars and other extraterrestrial destinations. Therefore, it ultimately doesn’t matter what you call these technologies that can make complex components out of exotic materials or can be used by individuals at home. They’re exciting regardless of the name.
First published June 23, 2016, on NIST's Taking Measure blog.
Jarred Heigel’s picture
Jarred Heigel
Jarred Heigel graduated from Penn State in 2015 with a Ph.D. in mechanical engineering, where he studied the thermal and mechanical response of metal parts during additive manufacturing processing. Before grad school, Heigel worked as a contractor with th National Institute of Standards and Technology (NIST) researching metal cutting processes; specifically how to measure the process to provide more accurate data to validate model predictions. See papers Heigel has co-authored here.
