Featured Video
Innovation Features
Maria Guadelupe
Rethinking traditional ways of working
Taran March @ Quality Digest
‘Here’s your package—what’s your hurry?’
Big brains, big ideas, big changes: Who's in charge?
Protolabs
MJF is suitable for complex, low-volume quantities of parts
Hilke Plassmann
Cognitive neuroscience will help businesses see below the surface of what consumers report
More Features
Innovation News
Preparing your organization for the new innovative culture
IoT solution includes advanced lab testing and real-world crowd testing
New system patches security holes left open by web browsers’ private-browsing functions
125 strategies to achieve maximum confidence, clarity, certainty, and creativity
MIT awards more than $1 million to organizations creating greater economic opportunity for workers
Berkeley Lab and Magic Leap Inc. scientists create widely controllable ultra thin optical components
$79 device delivers dedicated neural network processing to a range of host devices
Drip irrigation targets the plant and not the soil
New approach uses light instead of electricity
More News
Jennifer Lauren Lee
Innovation
Photonic Pressure Sensors vs. Mercury-Based Standard
New device goes head to head with traditional manometer
Published: Wednesday, May 11, 2016 - 15:15
When a team of researchers at the National Institute of Standards and Technology (NIST) Physical Measurement Laboratory (PML) first tested a new kind of pressure sensor two years ago, initial results showed it was faster and had higher resolution than the centuries-old mercury-based method for measuring pressure. The novel device, called a fixed length optical cavity (FLOC), works by detecting subtle changes in the frequency of light passing through a nitrogen gas-filled cavity about the size of a box of tissues.
Now the same research team has thoroughly vetted the FLOC against the U.S. mercury-based pressure standard, currently a world leader in pressure measurement. The verdict: The photonic sensor performs better than expected and in fact outperforms the traditional mercury system at low-pressure ranges. The work was carried out jointly by a team of NIST scientists from PML’s Sensor Science Division and Engineering Physics Division.
PML’s Jacob Ricker with the two FLOCs (copper boxes, center) and the mercury manometer (blue column, right).
“This is the biggest fundamental change to pressure measurement since the invention of the mercury manometer in 1643,” says Jay Hendricks, PML's Thermodynamic Metrology group leader. “This breakthrough will enable development of smaller and smaller standards and possibly chip-scale primary pressure standards in the future. Additionally, this technique can cover up to nine decades of pressure, a task that currently requires six different primary standards.”
Until now, the most reliable way to measure pressure has used a technique invented almost 400 years ago, involving a column of mercury whose height changes with pressure. But this type of device—called a manometer—is relatively slow, taking about a minute per measurement. It’s also bulky. The current U.S. primary pressure standard is a mercury manometer 3 m (about 10 ft) tall, that extends through the ceiling of the laboratory in which it is housed. Furthermore, manometers typically require mercury, a toxin whose use is currently being phased out of products and manufacturing internationally.
The FLOC, by contrast, is mercury-free and consists of a chamber approximately 15.5 cm (about 6 in.) long by 5 cm (about 2 in.) square, a fraction of the size of the U.S. standard manometer. The device works by comparing the changes in optical path length between a pair of mirrors attached to two separate channels, one in vacuum and the other filled with ultra high-purity nitrogen gas.
“The length of each channel is measured by tuning the frequency of a laser so that a standing wave is set up between the mirrors,” says PML’s Jacob Ricker. Ricker explains that when gas is pumped into the nitrogen channel (i.e., as the gas pressure increases), it takes the light a longer time to bounce between the mirrors. So the effect they measure is the same as if the channel were being physically lengthened. (Changes in pressure do physically distort the channels slightly, but the researchers have measured and characterized this source of noise so they know what to expect.) The property of gas that changes the speed of light is known as the material’s index of refraction.
Ricker holding a FLOC cavity with its two channels. The mercury manometer looms behind him. Click here for a closer look at the cavity.
With a change of pressure in the gas-filled channel, the frequency of the laser light bouncing around in that channel must change, too, in order to maintain a standing wave. The team has designed the system to compare this frequency change to the frequency of light in the vacuum channel, which remains the same. Measuring the changing frequency of the light in the gas-filled channel allows researchers to determine the gas’s index of refraction, a quantity that lets them work out the pressure. (For more information about how the FLOC works, see “World’s First Photonic Pressure Sensor Outshines Traditional Mercury Standard.”)
To vet the new instrument’s performance, Ricker hooked a FLOC and the manometer up to the same pressure source. But he couldn’t flood both devices with the same sample of pressurized gas because the FLOC relies on the ultra high-purity of its nitrogen gas for its accuracy. Instead, he connected the systems using a capacitance diaphragm gauge (CDG), a device that measures the difference between two pressures.
The head-to-head comparison and analyses show that the smaller, faster FLOC—each measurement takes less than a second to perform—is more precise than the manometer at pressures below about 1 kilopascal (kPa, approximately 0.15 lbs per square inch).
Alas, pitting the newcomer against the reigning champion of pressure measurements still amounts to a “he said, she said,” without additional checks in place. So the researchers built a second FLOC and tested all three instruments against each other.
They discovered that the FLOCs gave the same results to within about 1 part per million, while the disagreement between the manometer and either FLOC was up to 12 times worse. Furthermore, both FLOCs had a reproducibility and linearity of just 1 part per million at all pressures between 100 Pa and 100,000 Pa. (Linearity here means that the ratio of input to output is about the same at any pressure within that range.) And because both FLOCs were linear, the team was able to attribute the disagreement to nonlinearities in the manometer.
One reason for their excellent agreement? “We baked the FLOCs for two months at 373 K (100°C) in a vacuum,” says PML’s Patrick Egan. “Heating helps speed up the curing process for the bonding that was used to attach mirrors to the ends of each channel. Since the measurement of pressure in the FLOC comes from the measurement of length between the mirrors, it’s very important that the mirrors are attached to the channels with high stability.”
After this heat curing, the researchers saw a relative drift between the pair of mirrors on each channel of about 6 femtometers (million billionths of a meter) per hour—a tiny amount. “That’s smaller than the nucleus of a gold atom,” Egan says.
Although the team has beaten the manometer’s accuracy at low pressures, their analysis reveals that, for measurements at pressures above 1 kPa, the FLOC is two times less accurate than the manometer. But that’s not surprising, Egan says, since the FLOC’s measurement of pressure depends on how accurately researchers can calculate the refractive index of nitrogen. And ironically, that calculation is limited by how accurately researchers can measure nitrogen’s pressure with the best instrument they currently have: the mercury manometer.
So a long-term goal of the group is to create a new device to help them further shrink the FLOC’s uncertainties.
“To do that, we have to measure the refractive index of nitrogen better than anything that’s been done before,” Egan says. “And that’s what we’re working on now.”
Egan says the immediate next phase, however is to use the FLOCs alongside the manometer to calibrate customers’ pressure gauges this summer. “That will be the first step on a road that departs from the three-and-a-half-century-old measurement tradition,” he says.
Jennifer Lauren Lee’s picture
Jennifer Lauren Lee
Jennifer Lauren Lee is a science communicator in the Washington, D.C. area with specialization in physics writing, web design, editing, and multimedia. She is a technical writer and editor at the National Institute of Standards and Technology (NIST) where she writes monthly articles on physics topics for NIST’s Physical Measurement Laboratory (PML), as well as records and edits videos demonstrating physics concepts and experimental setups used at PML to maintain and distribute national standards. Lee has master’s degrees in specialized journalism and science, and bachelor’s degrees in English and world literature.
