No matter how much effort we put into meeting a quality standard’s requirements for continual improvement, there are times when we are not sure whether to call for a corrective action. Although there is no instrument that points to yes or no and determines when a corrective action is needed, I have a few simple rules to make your decision easier and a bit clearer.
When to generate corrective actions
Corrective actions are best suited for systemic issues or issues that affect the quality of your products or services. One-time issues usually aren’t suitable for corrective action unless they are customer complaints or they significantly affect the quality of your products or services.
Privacy Policy.
Corrective Actions
Hi Miriam,
I reviewed yur article on " when exactly should I use CAs? Well, your article was prepared only for clients who are in the service industries. Do you have some good practical case studies or examples for using Corrective Actons in the Aircraft and Aerospace industries? Please reply back. My email address is: kaiser876@gmail.com
Thank you
Regards
Kaiser Saifudin
Corrective Action Sample for Aircraft and Aerospace
Hello Kaiser, Thanks for your readership! I was trying to show examples that could work accross various industries actually. But here are some quick examples that come to mind:
Hope this helps.
Miriam
Corrective action
To me, even a single lapse is a System's failure, therefore, corrective action is neither meat nor fish. I believe that the corrective PROCESS must start with Containment, but it has then to grow to Preventive Action, or, even more effective, Predictive Action.
Corrective Action
Corrective Action Initiation
Thanks for this article.
I could not agree more.
We are managers of resources and must use judgment. I think the examples used show good judgment. Regulations, risk and customer satisfaction and other factors drive the appropriate response. If we do not respond appropriately, either by inaction or over reaction, events will end up managing us rather than us managing them.
RE: When to use a Corrective Action
Hi
I read your article with great interest, but in the end i wasn't sure how to interpret your point. I was left wondering:
I was very glad to read the "Take Two" section of the article - it helped me understand your point. Though I wonder if a desire to maintain brevity left a couple assumptions as implicit.
Based on this - I also wonder if your point really was "Be sure to design a corrective action process to accomodate the scale and importance of the entire range of incidents". With that understanding, we would be guided to the idea that we could create a Corrective Action Process small and light engough to note minor incidents (such as in example #1,2,3) with trivial amounts of time/effort investment, then close them with the corrective action of 'Correcting the form' or 'Notifying the person/group responsible for the error'. We would also then be in a position to truly know if Example #4 ("Incorrect Form Error for 3rd consectutive time") truly did occur and recognize it as possibly systemic.
Of course we all need the flexibility to exercise judgment in Corrective Action Processes as with all other aspect of management. A big part of that is deliberately designing the processes we all follow to provide appropriate guideance and record keeping so we can identify more significant issues quickly and easily.
Corrective Action is a process
Hello, thanks for your insighful feedback. Of what you mention, one thing strike me as overly important: the fact that Corrective action is indeed an entire process. This process does not end when a form has been filled out or even when actions have been put in place. Corrective Action goes all the way to verification and validation; the first being the mere checking of whether actions were indeed taken as proposed, the latter being whether the problem reoccur again or not. You should perhaps consider the impacts too:
The ISO standard does say that after creating a corrective action (request) you can evaluate whether actions are necessary.
About your point of how do we know is the first time, or second time...well yes you got a point. You will think Process Owners will be in charge but that may not always be the case.
thanks
Miriam
CARs and NCRs
Hi,
I thought I'd give my two cents on answering your point a little better. I had the same question about when is a corrective action needed. With regards to your concern on logging occurrences, you document them in a nonconformance log. Not every nonconformance will have a corrective action to follow though.
A corrective action can be taken depending on several factors. It is more of a judgment call depending on negative company impact. Here is an idea of when you should consider CA:
1) Problem resulting in high dollar amounts of rework/repair (user-defined base value)
2) A repeating trend of NCR
3) An audit finding in the quality process
4) A customer complaint
These aren't the only cases, but hopefully you get the idea. If a solution to an NCR isn't too complicated, you might fix it and never hear of it again. Conclusively, use your best judgment in weighing the severity of the problem when issuing corrective actions.
I hope this helps a little.
