In layman’s language, Six Sigma means great and fast improvement, which leads to virtual perfection. Another indicator of a successful application of the Six Sigma methodology is the degree of breakthrough. Sometimes, when customers demand zero defects at any cost, suppliers are forced to add an inspection stage to their system regardless of its process capability. Achieving zero defects for the Six Sigma’s sake leads to more waste and breeds undesirable approach toward Six Sigma. In theory, companies can achieve Six Sigma, but reality is sometimes different. It may be difficult to achieve Six Sigma level performance through process improvement using statistical techniques alone. Companies must consider using poka-yoke or failure-free methods to eliminate remaining opportunities for mistakes. Remembering Bill Smith’s Six Steps to Six Sigma, it’s possible to see the potential of poka-yoke. Smith’s six steps to Six Sigma are listed below: Many people think poka-yoke sounds like Ying and Yang. Poka-yoke means making it more difficult to make mistakes. When opportunities for mistakes are present and companies are unable to improve their processes through DMAIC, they must think of eliminating that possibility for mistakes. The six steps to Six Sigma listed above encourage companies mistake-proof each process in the defining phase. Because applying poka-yoke may involve decisions about the process design, it’s better to apply poka-yoke earlier rather than later in the product life cycle.
Poka-yoke, is about reducing process variability by minimizing possible ways of doing things. If a part is to be assembled on a base and it can only be assembled in one way, the assembler won’t make a mistake. A good example is a floppy disk, which only works, a if it’s inserted in a specified way. Another example is an order entry system that won’t process the customer order unless the required information is entered in a pre-specified way.
Depending upon the stage of occurrence of a mistake, companies can poka-yoke processes at the verification, control or design level to implement failure-free solution—or to prevent mistakes. At the verification level, the inspection should be before an item or service is delivered to the customer. Poka-yoke at the control level may include automatic adjustment or compensation to some undesired variation at the process level and eliminating the opportunity for error at the design level. The cost of implementing poka-yoke at the verification level, control level and design level decreases on the order of 100, 10 and one respectively.
Poka-yoke is most effective in case of human errors. Human errors aren’t prone to the application of SPC for prevention. Human errors are prevented by raising awareness to the chance for mistakes. There’s a simple rule of thumb: one error is human, two errors are a warning, and three errors require the quick application of poka-yoke. The person making mistakes or the design engineer must understand what sequence of events caused the repeated human error.
A failure-free methodology or a technological solution should be implemented. Typical human errors include the following:
The poka-yoke methodology includes the following steps:
Poka-yoke means making it difficult to make mistakes without focusing on the mistake itself. Integrating poka-yoke with Six Sigma makes Six Sigma a stronger methodology that generates a more dramatic improvement.
Sign In to get started!
