Inside Metrology
COX Instruments  |  02/16/2010
COX Instruments’s picture
Product News: Turbine Flowmeters with Ceramic Ball Bearings from Cox Instruments
Precision turbine meter line offers superior wear and temperature resistance
(Cox Instruments: Scottsdale, AZ) -- COX Instruments, a supplier of precision and industrial flow measurement instrumentation for the world’s most demanding applications, has announced its turbine flowmeters are now available with ceramic ball bearings. These rugged bearings are superior to standard 440C stainless steel and journal bearings in terms of wear resistance, and are less susceptible to fluid particulates. They are ideal for water and cryogenic applications, which have little to no lubricating properties.
In a wide range of applications, turbine flowmeter users must select the proper bearing material for fluid lubricity and process temperature to ensure long-term reliability. Water applications in particular may require high-friction journal bearings, which can shorten the meter’s linear flow range of operation. Ceramic ball bearings, on the other hand, have a low coefficient of friction and exhibit excellent wear-resistant characteristics. They are also an excellent choice for high-temperature applications, with temperatures up to 425°C (800°F).
COX Instruments offers one of the most linear and repeatable turbine flowmeters on the market. The unique design characteristics of COX meters, such as helical rotors with a 2–3 millisecond response and a single-bearing low-friction design allowing the meter to be mechanically linear over a wider flow range, result in unprecedented flow measurement performance. These strengths are complemented by COX’s advanced signal conditioning technology and state-of-the-art flow computers.
COX Instruments has provided thousands of quality turbine flowmeters contributing to the success of major industries, such as automotive, aerospace, test and measurement, metrology, process control, and manufacturing. COX precision turbine meters offer wide linear ranges, and when coupled with a flow computer, will measure accurately over the entire extended repeatable range. The meters are available with calibrations in various fluids and viscosity blends, as well as universal viscosity curves (UVCs) for extended temperature environments. They feature noncorrosive, stainless steel wetted parts and a choice of end fittings (e.g., AN, NPT, flanges), including specials to meet custom piping requirements. Manifold systems are also provided for extended flow range coverage. COX turbine meters can be paired with a complete line of ancillary electronic signal conditioners and flow computers.
All liquid and gas calibrations for COX meters are performed by Flow Dynamics, the first independent flow laboratory to receive the prestigious accreditation of the National Voluntary Laboratory Accreditation Program (NVLAP) offered by the U.S. National Institute of Standards and Technology (NIST). The NVLAP is in full conformance with the standards of the International Organization for Standardization (ISO) and the International Electrotechnical Commission (IEC), including, ISO/IEC 17025 and Guide 58, as well as, ANSI Z540.
COX customers receive a free ceramic ball bearing upgrade when submitting their meter for recalibration by Flow Dynamics.
To learn more, please visit www.cox-instruments.com or www.flow-dynamics.com.
COX Instruments
COX Instruments supplies precision turbine flowmeters and ancillary products for today's most demanding liquid and gas flow measurement applications. For over 50 years, COX flowmeters have been recognized for their uncompromised accuracy and reliability. Diverse customers can be found in the automotive, aerospace, test & measurement, metrology, process control, and manufacturing industries.
COX Instruments is accredited to AS9100 and ISO 9001 and compliant with other strict industry quality standards including TS16949.
