Inside Metrology
Fluke Corp.  |  10/27/2009
Fluke Corp.’s picture
Product News: New Fluke 27 II and 28 II, IP 67 Industrial Multimeters
Waterproof, dustproof, and can withstand a 10-foot drop.
(Fluke Corp.: Everett, WA) -- The new Fluke 27 II and 28 II digital multimeters define a new standard for operating in harsh conditions with the features and accuracy to troubleshoot most electrical problems. Both meters have an IP 67 (waterproof and dustproof) rating, MSHA approvals (pending), extended operating temperature range of -15°C to +55°C (5°F to 131°F, -40°C for up to 20 minutes) and 95-percent humidity. Both have been designed and tested to withstand a drop of three meters (10 feet). The new Fluke 20 Series multimeters are built to work in the toughest environments.
• Measure up to 1,000 V ac and dc
• Measure up to 10 A (20 A for 30 seconds)
• 10,000 μF capacitance range
• Frequency to 200 kHz
• Extended ac voltage bandwidth– 15 Hz to 20 kHz (28 II), 40 Hz to 30 kHz (27 II)
• Built-in thermometer conveniently allows you to take temperature readings without having to carry a separate instrument (28 II)
• Resistance, continuity, and diode test
• Min/max and average recording to capture variations automatically
• Peak min-max (28 II)
• Unique function for accurate voltage and frequency measurements on adjustable speed motor drives and other electrically noisy equipment (28 II)
Features:
New – IP 67 waterproof and dustproof protection, completely sealed for use in harsh environments
• Designed to withstand three-meter drop (with holster)
• High-resolution 20,000 count display mode (28 II)
• True-rms ac voltage and current for accurate measurements on nonlinear signals (28 II)
Average responding voltage and current for measurements (27 II)
New – Backlit keypad buttons allow for easy visibility in lowlit areas
• Large display digits and two-level bright white backlight for increased visibility
• Reversible holster for added protection when not in use
• Withstands hazardous 8,000 volt spikes caused by load switching and faults on industrial circuits and complies with second edition IEC and ANSI electrical safety standards
• Long battery life (800 hours)
• Relative mode to remove test lead resistance from low ohms measurements
• Auto and manual ranging for maximum flexibility
• Optional magnetic hanger for easy setup and viewing while freeing your hands for other tasks
• MSHA approval (pending)
Fluke Corp.
Fluke Corp. is a world leader in the manufacture, distribution, and service of electronic test tools and software. Since its founding in 1948, Fluke has helped define and grow a unique technology market, providing testing and troubleshooting capabilities that have grown to mission critical status in manufacturing and service industries. Primary market segments served include industrial/electronic service installation and maintenance, electrical and temperature, indoor air quality, calibration, and biomedical.
