(Artel: Los Angeles) -- At Death Valley for Mission No.3 of the Extreme Pipetting Expedition, Artel found that pipettes underdeliver by up to 35 percent in dry and hot environments. While volume delivery errors were partially reduced by prewetting pipette tips, underdelivery still persisted, and the pipettes were found to operate out of specification in most instances.
Laboratory technicians commonly encounter dry heat in their own work environments, which, although not as extreme as Death Valley, can nonetheless affect pipette performance and compromise assay results. For example, laboratories using analytical instruments, ovens, incubators, freezers and other devices requiring high power or open flames are prone to heat and low humidity. Heating and air-conditioning systems not equipped with humidifiers may also contribute to dry heat. To ensure pipetting accuracy and precision and strengthen data integrity, it is essential that laboratory scientists understand and compensate for this source of error.
“Laboratories often experience changes in humidity and temperature throughout the course of a year and data may be at risk,” says George Rodrigues, Ph.D., senior scientific manager at Artel. “Humidity and temperature can also vary across laboratories in different regions, between laboratories on different floors, and even in different sections of the same laboratory.”
As in previous missions, error caused by the environmental conditions at Death Valley was greater when pipettes were set to their minimum volumes than when they were set to their maximum volumes. A two-microliter pipette set to deliver its minimum volume of 0.2 microliter without prewetting underdelivered by 34.7 percent. Prewetting reduced the error to 30.9 percent, but the pipette was still operating outside its minimum-volume accuracy specification of 12 percent. When set to its maximum volume of two microliters without prewetting, the pipette underdelivered by 7.0 percent without pre-wetting and by 4.8 percent with prewetting, both outside of the manufacturer’s accuracy specification.
When working with larger liquid volumes, errors were also induced by the hot and dry conditions, but on a smaller magnitude. Without prewetting, a 20-microliter pipette at its minimum volume underdelivered by 16.8 percent, which is a significantly lower inaccuracy than exhibited by a non-prewet two-microliter pipette at its minimum volume (34.7% error). Prewetting the 20-microliter pipette prior to dispensing its minimum volume of two microliters reduced error to 7.4 percent.
“Based on data taken at Death Valley, we highly recommend pre-wetting pipette tips to reduce volume loss when pipetting in dry and hot environments,” says Doreen Rumery, Artel’s laboratory technical manager and quality control manager.
Liquid handling error experienced in dry heat is largely due to evaporation. The evaporation of a miniscule amount of liquid inside the pipette tip has a large effect on pipetted volumes, especially when target volumes are in the microliter range. When one microliter of liquid evaporates, it converts into more than 1,000 microliters of gas, expanding by a factor of 1,250 to 1,450 depending on temperature. This expansion prevents the pipette from aspirating the desired target volume.
The Extreme Pipetting Expedition is a multi-phase, year-long scientific study to illustrate the effect of laboratory environmental conditions on pipetting performance and data integrity. Previous missions explored how barometric pressure and how pipetting warm and cold liquids affect data integrity.
For more information, visit www.artel-usa.com/extreme/results3.htm.
Sign In to get started!
