ACQUIP Introduces Magnetic Base for Curved-Surface Laser Measurement
ACQUIP
Thu, 08/21/2014 - 16:00
(ACQUIP: Miami Beach, FL) -- ACQUIP Rotating Equipment Solutions, the industry leader for laser alignment launched the new adjustable magnetic base mount kit that enables any measurement arm or laser tracker to be mounted on plates, parts and any other curved surface, which makes it the ideal tool for eliminating the typical problems and limitations of traditional mounts.
In the past, traditional mounts required you to have a large and perfectly flat surface for the mount to affix properly. While any imperfection on the surface caused the mount to rock, giving you non-repeatable or false data. Whether a factory or machine shop, these mounts were not easily available or found at convenient locations. Oftentimes, you would find yourself producing your own mounts or plates, costing you more time and money. This impediment limited the reach and capability of your portable CMM device.
