Published: 08/25/2022
(Ultimation Industries: Roseville, MI) -- Indoor farming is all about maximizing food production per acre. But growers who want to further increase yields should consider growing “up” with the help of conveyor technologies that make use of the available vertical space within a facility, according to Ultimation Industries, a leading direct-to-consumer conveyor manufacturer for food processing, vertical farming, warehousing, delivery, and other industries.
Indoor vertical farming is expected to grow from $3.1 billion in 2021 to $9.7 billion worldwide by 2026, due to higher yields than conventional farming and Ultimation’s advances in lighting and other technologies, and capacity for year-round crop production.
“Conveyors are one of the simplest and quickest productivity improvements a fast-growing business can implement, and are especially suited to the vertical farming industry,” said Richard Canny, president of Ultimation. “Simple roller conveyors or overhead I-beam trolleys can have a payback of days or weeks, while larger custom-built systems often have payback periods of only 3 to 6 months.” Ultimation is currently building the material handling system for what is believed to be the world’s largest indoor vertical farming facility.
Perhaps the most obvious way conveyor technologies can help increase indoor farming productivity is by taking advantage of unused vertical space above a work area. Overhead conveyors can lift growing trays when they’re not being actively managed and bring them back to operator level for tending and harvesting, allowing more produce to be grown within the same footprint.
Conveyors can also help reduce the manual labor of carrying items by hand, quickly and safely transporting plants from point A to point B. According to Canny, systems can be engineered to seamlessly integrate with harvesting and packing equipment available through Ultimation’s expansive partner network.
Ultimation uses materials made of galvanized steel, zinc-plated materials, and powder-coated frames that are approved for food-grade applications and are easily cleaned—another productivity savings for indoor farmers. Ultimation can also design systems for hanging towers and growth pods made of food-grade plastic.
Different types of conveyor systems are used for different parts of the growing process, according to Canny. For example, the sections of the farms where plants are sitting still can use simple, standardized material handling systems. Vertical format conveyors, such as hanging towers, or horizontal formats, such as growing trays, can be customized to match the grower’s needs.
Once plants are grown, more sophisticated technologies, such as automated motorized conveyors and automatic storage and retrieval systems, are needed to safely move produce to the harvesting area. The most commonly used industrial automation devices for indoor farming are gravity rollers, belts, and skate wheel or flow rail conveyors. These systems use the force of gravity to move the load, allowing the product to roll along the upper surface.
More recently, the technology in larger vertical farming systems includes motorized and overhead conveyors that take advantage of the generally unused vertical space above the working area. Using curved sections or even lifters, they bring produce down to operator level and back up to higher elevations as needed.
Power and free conveyors are the ultimate in space and volume optimization for vertical farming systems because they enable tight concentration of product in some areas while also enabling separation of the products for movement to processing areas.
“The best-planned and best-run indoor farming facilities take into account the product’s growth cycle and will likely use a combination of a conveyor system designs to maximize productivity,” says Canny. “Our engineers understand the economics of indoor farming and can help growers design, build, and implement material handling solutions that meet their needs and budget.”
For more information about using conveyors to maximize indoor farming productivity, visit https://www.ultimationinc.com/.
Ultimation Industries’ conveyors allow indoor farms to grow more produce within the same footprint by making use of vertical space.
[1] https://www.ultimationinc.com/
[2] https://www.marketsandmarkets.com/Market-Reports/vertical-farming-market-221795343.html
[3] https://www.ultimationinc.com/products-conveyor-systems/gravity-conveyor/
[4] https://www.ultimationinc.com/products-conveyor-systems/belt-conveyor-system/
[5] https://www.ultimationinc.com/products-conveyor-systems/overhead-conveyor/
[6] https://www.ultimationinc.com/qimarox-usa/
[7] https://www.ultimationinc.com/products-conveyor-systems/power-and-free-conveyors/
