Featured Product
Standards Features
Jon Speer
As a medical device manufacturer, you can expect to be inspected
It takes more than a good capability ratio
William A. Levinson
Ineffective CAPA processes are the greatest source of ISO 9001 audit findings
A concise history of FDA’s risk-based Site Selection Model
More Features
Standards News
Streamlines shop floor processes, manages nonconformance life cycle, supports enterprisewide continuous improvement
Allows construction industry to collaborate across projects and national borders
Enhances accreditation services portfolio across global market
Features illustrations as applied in real-world organizational contexts
Standards like ISO 10303 and ISO 14306 help to keep planes high in the sky
Amendments to the California Consumer Privacy Act go into effect no later than July 2020
VQIP allows for expedited review and importation for approved applicants that demonstrate safe supply chains
Intended to harmonize domestic and international requirements
User-friendly database offers 3,000 classes available in 35 cities in North America
More News
NIST
Standards
Study Finds Failure Points in Firefighter Protective Equipment
Fire experiments help improve match between standard requirements and real-life conditions
Published: Monday, December 19, 2011 - 17:50
(NIST: Gaithersburg, MD) -- In fire experiments conducted in uniformly furnished but vacant Chicago-area townhouses, National Institute of Standards and Technology (NIST) researchers uncovered temperature and heat-flow conditions that can seriously damage facepiece lenses on standard firefighter breathing equipment, a potential contributing factor for first-responder fatalities and injuries.
The findings are detailed in a report from a research study sponsored by the U.S. Fire Administration and Department of Homeland Security. The work is an important step toward improving what may be the most vulnerable component of a firefighter’s protective gear in high-heat conditions: the facepiece lenses of the so-called self-contained breathing apparatus, or SCBA.
Failure of the lens can expose a firefighter to toxic gases and can result in burns to the respiratory tract as well as asphyxiation. In several SCBA-related deaths, degraded masks were found affixed to the faces of victims while their equipment continued to supply air.
In two of four realistic living-room fire scenarios tested by NIST, “lenses exhibited bubbling and loss of visual acuity, as well as severe deformation, and, in one case, a hole,” the NIST team says.
Opening the door provided additional air to a smoldering living-room fire and caused the fire to increase in burning rate and flames to extend out the doorway, resulting in high temperatures and heat flows that melted a hole in the mask. Credit: NIST
The researchers tested five models of SCBA facepieces, each from a different manufacturer. In all cases of lens degradation, the damage was due to temperatures and heat fluxes that exceeded performance limits of polycarbonate, the lens material commonly used in SCBA for firefighters.
“Our results do not suggest, in any way, that that lens failures are due to the manufacturers,” explains NIST’s Nelson Bryner, a co-author of the report. “All the lenses tested were consistent with requirements specified in standards.”
In the United States, SCBA makers must submit their products for certification testing before they can be sold. Certification requires passing the “heat and flame test” specified in a standard by the National Fire Protection Association. Citing the conclusions of other researchers, the NIST team notes that this test is conducted at high temperatures, but “it does not capture the conditions of temperature, heat flux, and duration that a firefighter might experience.”
The townhouse fire experiments will inform efforts to improve the match between standard requirements and real-life conditions. Until now, these efforts have been hampered by lack of information regarding the high-temperature and high-heat-flow performance of polycarbonate lenses and the actual fire-scene conditions that have resulted in lens failures.
The NIST experiments were conducted in two-story townhouses in Bensenville, a suburb northwest of Chicago, in cooperation with the Bensenville and Chicago Fire Departments and the Bureau of Alcohol, Tobacco and Firearms. In each of the four “furnished-house experiments,” the conditions were nearly identical, save for the location of polyurethane heads outfitted with a SCBA facepiece and controlled variations in fire exposure conditions, adjusted, for example, by opening and closing of doors and windows at specified times.
Rooms were equipped with devices to record temperatures rapidly at regular intervals between ceiling and floor. Facepieces also were equipped with sensors, on the inside and the outside of the lenses and in the immediately surrounding space. A gauge to measure heat flow, or flux, was positioned next to the facepieces.
The most devastating damage occurred in a scenario akin to one in which a firefighter would enter a burning living room from a front porch. The living room fire smoldered for five minutes after ignition. Opening the front door literally breathed life into the smoldering fire. The rush of heat from the now blazing living room transformed a relatively cool environment on the porch into an inferno. The SCBA lens’s exterior surface temperature reached 280°C (536°F), about the midpoint of the range of published polycarbonate melt temperatures. The lens developed a significant hole, according to the NIST report.
“The next step is to identify the exposure limit just before thermal degradation occurs,” the NIST researchers write. “Data on the limits of the equipment would be valuable information for the fire service to help prevent further injuries and fatalities related to SCBA equipment failure.”
NIST’s picture
NIST
Founded in 1901, The National Institute of Standards and Technology (NIST) is a nonregulatory federal agency within the U.S. Department of Commerce. Headquartered in Gaithersburg, Maryland, NIST’s mission is to promote U.S. innovation and industrial competitiveness by advancing measurement science, standards, and technology in ways that enhance economic security and improve our quality of life.
