Featured Video
Metrology Features
Mike McDonald
Or motivate them...
Jennifer Lauren Lee
‘Bob’ takes on ultra-high precision measurements for industry
Ryan E. Day
High-accuracy portable CMM helps land tight-tolerance aerospace contracts
Jennifer Lauren Lee
Nobody knows exactly how bright the Moon is... but that could change soon
More Features
Metrology News
More News
DE-STA-CO Introduces Manual Clamp Series
Adjustable power clamp primarily for prototype fixtures
Published: Thursday, October 8, 2015 - 11:48
(DE-STA-CO: Auburn Hills, MI) -- With the new 52H-3E series, DE-STA-CO is offering a very individualized, adjustable manual power clamp primarily for prototype fixtures. The manual power clamps are available in two sizes—50 and 63. They have a completely closed aluminum housing that protects the inner mechanical parts from weld splatters. The opening angle is close to infinitely variable with adjustments from zero to 135 degrees. An Allen key is used to open the retaining mechanism and to clamp it again to the desired setting.
There are two manual levers available that can be mounted on the left or right. While the “H0” model can be installed in different positions, the “HS” model can be welded on as desired, even at an axially bent angle, thus utilizing the ergonomic position. There is a large array of U and side clamping arms available.
The models of the new series are available with or without sensors. Colored LEDs reliably indicate the current status of the clamp: Green means ready for operation; yellow and red indicate that the clamp is in open and closed position, respectively. In order to prevent damage, the sensors are divided into two parts: The sensors are in the clamp; the connector shell with the LEDs is accessible from the outside.
The new series is designed for use in a temperature range from negative 13 to positive 158 degrees Fahrenheit (negative 25 to positive 70 degrees Celsius). The maximum holding force is 960 ft.lb (1,300 Nm) for model 50 and 1330 ft.lb (1,800 Nm) for model 63. Both models can replace series 82M-3E.
DE-STA-CO’s picture
DE-STA-CO is a global automation and workholding company that provides productivity solutions to the manufacturing industry. Quality and service have helped DE-STA-CO evolve from a single stamping shop into a leader in the design and manufacture of cost-reducing, flexible products. With operations in the United States, Brazil, China, France, Spain, Germany, India, the Netherlands, Thailand and the United Kingdom, DE-STA-CO offers standard and custom solutions for industrial customers around the world. DE-STA-CO is part of the Engineered Systems segment of Dover Corp., a multi-billion dollar diversified global manufacturer.
