Featured Video
Metrology Features
Amanda Hunt
CNC milling machines are considered the ideal solution for preparing tensile specimens
Ryan E. Day
FARO’s Cobalt Array Imager helps Hubbell speed up FAI and time-to-market
NIST
Scanner runoff event pushes new standard toward the finish line
I'll believe it when I see it in my AR goggles
Mike Richman
The framework of the smart factory takes shape
More Features
Metrology News
Robot-served vision, new force-testing products, and electronic gauges at booth No. 135532
Machine demos, technology previews, and a daily happy hour at booth No. 338319
Other exhibits will feature machine tools to demonstrate tool setting, probing, machine monitoring, and robotic gauging
Marposs Mida Laser 75P Hybrid combines a noncontact laser and touch probe in one system
LEXT OLS5000 3D laser confocal scanning microscope received a Silver award
More News
Brian Simonds
Metrology
A Little Light Construction
Laser welding in three acts
Published: Monday, December 5, 2016 - 18:13
Welding is said to be more art than science. In part, this is a nod to the vital, skilled work that welders perform. It’s also recognition of the fact that the physics of the process is really, really difficult to understand.
I joined a NIST project on laser welding about two years ago. Before this, I had studied materials for solar panels and had done some work in laser processing, but I had little interest in laser welding. What eventually drew me in, and what motivates me now, is just how complex laser welding is and the opportunity to contribute to the understanding of a process that is so intertwined with everyday life, yet so mysterious.
Act I: Creating a keyhole
The laser welding process begins, as one might imagine, when a laser is focused to the surface of a metal. Although the surface initially reflects most of the light, it absorbs enough to cause significant heating. This heating slightly changes the way the metal interacts with the light, which in turn causes more absorption and even more heating. Once the metal gets hot enough, it begins to melt and evaporate.
The now-molten metal pool reacts to this evaporation by recoiling and creating a depression in the surface, like a trampoline reacting to a heavy load. When this depression is deep enough, it sends some of the reflected light back onto itself, which increases the absorbed light, creating more melting, generating more evaporation, making a deeper depression, creating more absorption, then more melting, and so on. This continues until all the light is absorbed and a deep hole, called a keyhole, forms. In cross section, this looks something like a molten metal tornado with a hollow cavity surrounded by a turbulent funnel of very hot liquid.
This all happens within the first few milliseconds.
In their textbook Modern Welding Technology (Pearson, sixth edition), which has been metaphorically welded to my neocortex, Howard B. Cary and Scott Helzer estimate that as much as 50 percent of the United State’s gross domestic product relies on welding in some form or another. The obvious applications of welding are in the manufacturing of big things like cars and trains, but there are less obvious ones like the battery casing in your mobile phone or the metal stents used to reopen clogged arteries.
It turns out that we can use laser welding in many of these manufacturing scenarios, and by doing so, we can realize numerous benefits. In some applications, the laser’s tightly focused beam makes for better precision welds like those needed in biomedical devices, batteries, and nuclear containment vessels, but in most other cases, using lasers is just good business.
For instance, most of a laser’s energy goes into making the weld itself, with little wasted on heating the surrounding area. Less waste means lower utility bills. Also, the latest laser technology is based on fiber optics, which we can mount directly to manufacturing robots, speeding up production lines and increasing manufacturing throughput. Recent studies also show that the ecological footprint of laser welding over traditional welding is significantly smaller both in terms of resources needed and hazardous waste produced.
Being a former solar-cell guy, I find this benefit particularly motivating.
Act II: A tornado of molten metal
Due to the chaos below a weld spot, a hot cloud forms above the surface of our molten metal tornado. This cloud is made up of four different states of matter: solid particles, liquid droplets, a hot gas, and even a bit of plasma. Each of these states of matter interacts with the molten surface and the incoming light in its own special way.
Industry chooses metal alloys to suit a particular application based on its requirements for strength, hardness, corrosion resistance, etc. Interestingly, many properties of steels are owed not to the iron, but to the small amounts (often a fraction of 1 percent of the total) of other elements like carbon, phosphorous, silicon, and zinc. Like a chef tweaking the taste of a soup with spices, a metallurgist tunes a metal’s properties by sprinkling in small amounts of these elements. However, the dynamic process of laser welding can alter the flavor by throwing out more of some elements than others. This can leave you with a welded region that “tastes” slightly different than the surrounding unwelded regions. This mismatch in properties can lead to cracking, fatigue, stress, or corrosion.
In other words, a bad weld.
What I do is measure the trace alloying elements as they are flung out of the tornado. I find them by using a process a little like the Bunsen burner experiments you might have done in high-school chemistry. If you recall, you put a “mystery” substance into a flame and discovered its identity by observing the colors of light it gave off on a special viewer. In my case, though, I’m choosing to make some colors brighter by selectively targeting elements with a second, specially tuned laser that shoots through the weld plume. This technique causes those trace elements to generate more light, which allows me to see elements that would otherwise be too faint.
Act III: The cool-down
Although the storm has passed, how the weld will perform is being determined. Once the laser has moved on, the molten pool of metal rapidly cools and becomes a solid again, now bridging what was previously a gap between two separate pieces of metal. The speed at which this bridge is formed (the cooling rate) determines an awful lot about the quality of the weld’s final structure. The cooling process will ultimately determine if cracks will form and what structure the welded metal will have.
In order to study the resulting weld quality, we have to take the weld apart and look at it. To do this, we turn to our project partners at NIST’s Material Measurement Laboratory. There they have the capability to dissect a weld to look for cracks and defects. Using an array of atomic-scale imaging techniques, materials research engineer Ann Debay Chiaramonti in the Nanoscale Reliability Group can see how the weld process displaced individual atoms. Metallurgist and welding expert Jeffrey Sowards in the Structural Materials Group tests welds by pulling them apart or compressing them to their breaking point under extremely heavy loads. Studying these processes is vital to understanding why welds fail and how those failures are related to the welding process.
Due to the complexity of the laser welding process, directly studying the process in a systematic way can be difficult experimentally. Therefore, the welding community relies on complex models to help solve the mystery. The quality of the output of these models is inherently linked to the quality of data inputs used.
As the saying goes: garbage in, garbage out.
In order to help guide the weld models toward more realistic solutions, our team is developing measurement tools to accurately measure all inputs necessary at every stage in the laser welding process. The ability to accurately measure these properties over such large and dynamic time, length, and temperature ranges requires a unique combination of capabilities that only NIST can provide, making this work vital for the welding community.
Although laser welding has the potential to replace 25 percent of existing welding activities, it is currently only used in about 0.5 percent. Making up that difference and realizing all of the technological, economic, and environmental benefits that go along with it will require efforts like the one we are pursuing at NIST. I’m proud to be part of such a group and happy to be contributing to a research effort that has the potential for making a large, meaningful impact.
First published Nov. 7, 2016, on the Taking Measure blog.
Brian Simonds
Brian Simonds first started working at NIST in Gaithersburg, Maryland, as an undergraduate student in 2004, an experience that inspired his decision to enter graduate school. After an eight-year hiatus to obtain a Ph.D. in applied physics at the Colorado School of Mines and complete a postdoc appointment at the University of Utah, he is happy to be back at NIST, only this time in the mountains of Boulder, Colorado. He is an avid rock climber and ski mountaineer and is exquisitely mediocre at both.
