Featured Product
Innovation Features
Nicola Olivetti
Digital visual management puts visual tools into the hands of team members across multiple sites
Venkat Viswanathan
It’s not just about energy
Steven Brand
Building better, smarter, and more secure supply chains
Matthew M. Lowe
Confronting the fear of being displaced by machines
Tara García Mathewson
Cognitive strategies instruction moves students toward achieving knowledge transformation
More Features
Innovation News
Deep Reality Viewer creates stereo, high-definition 3D images without using a monitor
Wing’s shape shifts automatically for aerodynamic loads (e.g., takeoff, landing, cruising)
Process concerns technology feasibility, commercial potential, and transition to marketplace
Identifying the 252 needs for workforce development to meet our future is a complex, wicked, and urgent problem
How established companies turn the tables on digital disruptors
Building organizational capability and capacity to create outcomes that matter most
‘What if we could develop electronic systems that we wrap around a bridge or cover the walls of our office?’
System breaks down complex designs into easily modifiable shapes for custom manufacturing and 3D printing
How to solve any problem and make the best decisions by shifting creative mindsets
More News
David L. Chandler
Innovation
Using Artificial Intelligence to Engineer Materials’ Properties
New system of ‘strain engineering’ can change a material’s optical, electrical, and thermal properties
Published: Wednesday, February 27, 2019 - 13:02
Applying just a bit of strain to a piece of semiconductor or other crystalline material can deform the orderly arrangement of atoms in its structure enough to cause dramatic changes in its properties, such as the way it conducts electricity, transmits light, or conducts heat.
Now, a team of researchers at MIT and in Russia and Singapore have found ways to use artificial intelligence to help predict and control these changes, potentially opening up new avenues of research on advanced materials for future high-tech devices.
The findings appear this month in the Proceedings of the National Academy of Sciences, in a paper authored by Ju Li, MIT professor of nuclear science and engineering and of materials science and engineering; MIT Principal Research Scientist Ming Dao, and MIT graduate student Zhe Shi, with Evgeni Tsymbalov and Alexander Shapeev at the Skolkovo Institute of Science and Technology in Russia; and Subra Suresh, the Vannevar Bush Professor Emeritus and former dean of engineering at MIT and current president of Nanyang Technological University in Singapore.
Already, based on earlier work at MIT, some degree of elastic strain has been incorporated in some silicon processor chips. Even a 1-percent change in the structure can in some cases improve the speed of the device by 50 percent, by allowing electrons to move through the material faster.
Recent research by Suresh, Dao, and Yang Lu, a former MIT postdoc now at City University of Hong Kong, showed that even diamond, the strongest and hardest material found in nature, can be elastically stretched by as much as 9 percent without failure when it is in the form of nanometer-sized needles. Li and Yang similarly demonstrated that nanoscale wires of silicon can be stretched purely elastically by more than 15 percent. These discoveries have opened up new avenues to explore how devices can be fabricated with even more dramatic changes in the materials’ properties.
Strain made to order
Unlike other ways of changing a material’s properties, such as chemical doping, which produce a permanent, static change, strain engineering allows properties to be changed on the fly. “Strain is something you can turn on and off dynamically,” Li says.
But the potential of strain-engineered materials has been hampered by the daunting range of possibilities. Strain can be applied in any of six different ways (in three different dimensions, each one of which can produce strain in and out or sideways), and with nearly infinite gradations of degree, so the full range of possibilities is impractical to explore simply by trial and error. “It quickly grows to 100 million calculations if we want to map out the entire elastic strain space,” Li says.
That’s where this team’s novel application of machine learning methods comes to the rescue, providing a systematic way of exploring the possibilities and homing in on the appropriate amount and direction of strain to achieve a given set of properties for a particular purpose. “Now we have this very high-accuracy method” that drastically reduces the complexity of the calculations needed, Li says.
“This work is an illustration of how recent advances in seemingly distant fields such as material physics, artificial intelligence, computing, and machine learning can be brought together to advance scientific knowledge that has strong implications for industry application,” Suresh says.
When a small amount of strain is applied to a crystalline material like silicon, its properties can change dramatically; for example, it can shift from blocking electrical current to conducting it freely like a metal. Credit: Frank Shi
The team studied the effects of strain on the bandgap, a key electronic property of semiconductors, in both silicon and diamond. Using their neural network algorithm, they were able to predict with high accuracy how different amounts and orientations of strain would affect the bandgap.
“Tuning” of a bandgap can be a key tool for improving the efficiency of a device, such as a silicon solar cell, by getting it to match more precisely the kind of energy source that it is designed to harness. By fine-tuning its bandgap, for example, it may be possible to make a silicon solar cell that is just as effective at capturing sunlight as its counterparts but is only one-thousandth as thick. In theory, the material “can even change from a semiconductor to a metal, and that would have many applications, if that’s doable in a mass-produced product,” Li says.
While it’s possible in some cases to induce similar changes by other means, such as putting the material in a strong electric field or chemically altering it, those changes tend to have many side effects on the material’s behavior, whereas changing the strain has fewer such side effects. For example, Li explains, an electrostatic field often interferes with the operation of the device because it affects the way electricity flows through it. Changing the strain produces no such interference.
Diamond’s potential
Diamond has great potential as a semiconductor material, though it’s still in its infancy compared to silicon technology. “It’s an extreme material, with high carrier mobility,” Li says, referring to the way negative and positive carriers of electric current move freely through diamond. Because of that, diamond could be ideal for some kinds of high-frequency electronic devices and for power electronics.
By some measures, Li says, diamond could potentially perform 100,000 times better than silicon. But it has other limitations, including the fact that nobody has yet figured out a good and scalable way to put diamond layers on a large substrate. The material is also difficult to “dope,” or introduce other atoms into, a key part of semiconductor manufacturing.
By mounting the material in a frame that can be adjusted to change the amount and orientation of the strain, Dao says, “we can have considerable flexibility” in altering its dopant behavior.
Whereas this study focused specifically on the effects of strain on the materials’ bandgap, “the method is generalizable” to other aspects, which affect not only electronic properties but also other properties such as photonic and magnetic behavior, Li says. From the 1-percent strain now being used in commercial chips, many new applications open up now that this team has shown that strains of nearly 10 percent are possible without fracturing. “When you get to more than 7 percent strain, you really change a lot in the material,” he says.
“This new method could potentially lead to the design of unprecedented material properties,” Li says. “But much further work will be needed to figure out how to impose the strain and how to scale up the process to do it on 100 million transistors on a chip [and ensure that] none of them can fail.”
“This innovative new work demonstrates potential to significantly accelerate the engineering of exotic electronic properties in ordinary materials via large elastic strains,” says Evan Reed, an associate professor of materials science and engineering at Stanford University, who was not involved in this research. “It sheds light on the opportunities and limitations that nature exhibits for such strain engineering, and it will be of interest to a broad spectrum of researchers working on important technologies.”
The work was supported by the MIT-Skoltech program and Nanyang Technological University.
David L. Chandler’s picture
David L. Chandler
David L. Chandler is an award-winning freelance writer and a photographer. Chandler began writing about science in 1975 and since then has authored two books and written thousands of published articles circulated in newspapers and magazines including the Chicago Tribune, Baltimore Sun, San Francisco Examiner, and the Boston Globe magazine, NewScientist, Smithsonian, Innovation, Wired, and many more. Forbes listed Chandler as one of the 500 most influential journalists and he has been included on three Who’s Who lists. Chandler has made numerous television, radio, and public-speaking appearances; participated on several universities’ panel discussions; and serves as a judge for the fellowship’s application process at Massachusetts Institute of Technology (MIT).
