MultiCal 14 is NIST-certified.
(E Instruments: Langhorne, PA) -- The MultiCal 14 temperature calibrator is designed to meet your test and calibration needs in the field or laboratory:
- Measure and simulate dc voltage, resistance, thermocouples, and RTDs
- Rugged and easy to use
- Able to measure 10 types of thermocouples (R, S, B, E, K, J, T, N, L, and U)
- Able to measure 6 types of RTDs (Pt100, Pt1000, Pt200, Pt500, Cu50, and Cu10)
- An accuracy of ± 0.02 percent
The NEW, MulitCal 14 temperature calibrator is a compact, light weight, and easy to use hand-held temperature calibrator that measures and simulates DC voltage, resistance, thermocouples, and RTDs. The MultiCal 14 temperature calibrator can display five digits for measurements and six digits for source values. The MultiCal 14 includes:
- A Dual Liquid Crystal Display with white LED back-light
- The DC voltage output range of: 100mV; 1V; while it can measure up to: 50mV; 500mV
- A measuring resistance of: 500Ω; 5KΩ, and an output resistance of: 400Ω; 4KΩ
- A holster is shipped with every unit
- An automatically power off feature that turns off within 10 minutes if not used
- A low battery display symbol, so you know when to change the battery
- An automatic cold-end temperature offset
For more information, visit www.E-inst.com
E Instruments
E Instruments International manufactures and markets a complete range of innovative instrumentation solutions encompassing Combustion Gas Analyzers, Indoor Air Quality, Calibrators, and Test and Measurement equipments especially design for the power, process, industrial, institutional, food, and HVAC markets.
